I originally designed this project using a Raspberry Pi Model B, USB WiFi adapter two ACS712 current sensors and a MCP3008.
In less than a year the SD card became corrupt and stopped working. I have since discovered the Particle Photon so I'm re-designing the project again using the Photon in place of the Raspberry Pi.
Have you found your base "zero current" readings to be consistent? Mine have been consistently inconsistent. What I do now is every two hours, if the washer hasn't run, average out the last 90 readings (~1/min) and that becomes my new base value (off).
