lipChargerSupportWithClaws.stl
Lipo charger board support. It has holes to secure it to the chassis, and claws hold the board in place.
Standard Tesselated Geometry - 65.07 kB - 03/12/2016 at 22:44
Download
lipChargerSupportBasic.stl
Very basic lipo charger board support. It only has holes to secure it to the chassis. To secure the actual charger to this support, use double tape. A non tape version is coming.
Standard Tesselated Geometry - 43.48 kB - 03/11/2016 at 23:46
Download
R.Ian_perfboard.pdf
Perfboard version of the electronics (PDF)
Adobe Portable Document Format - 856.75 kB - 03/05/2016 at 06:20
Preview
Perfboard version of the electronics (JPG)
JPEG Image - 499.71 kB - 03/05/2016 at 06:20
Preview
Perfboard version of the electronics (PNG)
Portable Network Graphics (PNG) - 266.85 kB - 03/05/2016 at 06:20
Preview
R.Ian_perfboard.svg
Perfboard version of the electronics (SVG)
svg+xml - 167.78 kB - 03/05/2016 at 06:20
Preview
R.Ian_perfboard.fzz
Frizing file for the perfboard version of the main electronics board.
fzz - 15.33 kB - 03/05/2016 at 06:20
Download
R.Ian_breadboard.fzz
Frizing file for the breadboard version of the main electronics board.
fzz - 11.79 kB - 03/05/2016 at 06:20
Download
r_ian.stl
The chassis of the robot.
Print with stiff material such as PLA, ABS, nylon...
Standard Tesselated Geometry - 667.14 kB - 02/29/2016 at 22:31
Download
r_ian_tyre2.stl
A version of the tyres with gripping bars for better traction on various surfaces. Made for printing in ninjaflex
Standard Tesselated Geometry - 521.91 kB - 02/29/2016 at 22:31
Download
r_ian_wheel.stl
The wheels of the robot (same for each side), meant for printing out of PLA, ABS, etc.
Standard Tesselated Geometry - 450.66 kB - 02/29/2016 at 22:31
Download
r_ian_electronics_plate.stl
This part is there to secure the electronics on the chassis. Print with stiff material such as PLA, ABS, nylon...
Standard Tesselated Geometry - 227.40 kB - 02/29/2016 at 22:31
Download
r_ian_front_sensor_servo_fixation.stl
Used to secure the sensor servo to the chassis.
Standard Tesselated Geometry - 106.87 kB - 02/29/2016 at 22:31
Download
r_ian.scad
The openscad file containing all the parts for this robot.
scad - 27.16 kB - 02/29/2016 at 22:31
Download
