Hackaday.io Hackaday.io
Sign up Log in
Clearcut: Direct manipulation laser cutter
Clearcut is a system for direct manipulation with laser-cutters. The system consists a semi-transparent, projected display on laser cutter.
touchaddicttouchaddict
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1 comments
4 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 1
View Gallery
249
1
4
3
Team (1)
  • touchaddicttouchaddict
Join this project's team
  • Interactive Laser Cutter
LASER CUTTER fabrication
This project was created on 04/30/2014
Description
The laser-cutter, enables fast and high quality cutting and engraving of a wide range of materials. However, the method by which users interact with this and similar tools is still very primitive. The process of drafting a design and executing the cut still contains many intermediate processes introducing many possible complications.
Clearcut is a system for direct manipulation with laser-cutters. The system consists of a semi-transparent, projected display and optical tracking system interfaced with a laser cutter so that users can draw and edit virtual graphics on top of their work piece which can then be cut by the laser cutter. The system also helps users make virtual copies of physical artifacts.
Clearcut offers advantages currently only accessible with hand fabrication such as letting users adjust designs quickly and iteratively based on visual feedback by virtue of stylus, and letting users use ruler, protractor and more as if they were working on the physical piece directly
Details
Log In/Sign up to comment
Sign up with Github
OR
georgefomitchef wrote 02/13/2016 at 17:02 • point
The best engraving with a diode laser
We would like to give 50 USD as a special prize for the best engraving using 2W or 3.5W
diode laser
http://endurancerobots.com/products/laser-cutters-accessory/laser-cutter-accessory-engraving-samples/
Not necessarily Endurance L-Cheapo.
Please send your pictures to gf@endurancerobots.com or place them in our facebook group: https://www.facebook.com/Endurance-1399951053640252/?pnref=lhc
这是一款桌面小型激光切割机,可以直接连接Lasermaker 软件使用。主要针对创客教育,K12教育,高等院校,以及家庭创客使用。采用455nm蓝光半导体激光发射器,激光功率10W,最大可一次切割8mm厚的椴木板。由于采用的半导体激光发射器采用了风冷技术,免去水洗,主打便携。
Project Owner Contributor
Destop small laser cut machine
wilsonzhangwilson.zhang
WYSIWYC- What you see is what you (laser)cut
Augmented Reality Laser-cutting/CNCing
laser targeting system computer
orlandomendezjr
mendezjrmendezjr
Cardboard laser cut AR glasses - 70-90 FOV
Augmented Reality Cardboard Glasses
kajKaj
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Clearcut: Direct manipulation laser cutter", please tell us the reason.
Send message
Remove Member
