Submersible/waterproof 3D printed boxes
The goal of this project is to design 3D printable boxes that can endure underwater pressure.
The goal of this project is to design and test 3D printable boxes/enclosures in order to obtain waterproof containers, but also pressure vessels capable of underwater operation without leaking water inside. Those designs will be tested at various depths.
The goal is to have as much part as possible 3D printable, including the gaskets.
diveBoxCylinder.stl
This is a test box for the base design, with a cylinder body with flat end.
Standard Tesselated Geometry - 397.00 kB - 03/01/2016 at 17:05
Download
diveBoxCylinder.scad
The scad file contains multiple modules for the various versions of the divebox, the gasket and a lid.
scad - 2.86 kB - 03/01/2016 at 17:05
Download
