v3 Now in Eagle format
10/23/2016 at 21:23 • 0 commentsUpdated layout and format
2xAA RF Limits
04/09/2016 at 06:15 • 0 commentsAfter using this in one of my other projects (wireless tank gauge) , ive come to find something i overlooked and did not notice in my initial use. While the 328p (1.8v-5.5v) will happily run off 2xAA (or AAA) batteries either Alkaline or NIMH the NRF24 is a little more fussy, and is rated for 3v3, apparently though it can handle 5v logic connections but the vcc must be 3v3. So as my 2xAA NIMH started to discharge it cut out at 2.6v, so its more suited to the upper charge states of 2 alkalines (2.6v-3v), or 3 nimh (2.8v-3.6v).
Free V1 PCB
03/26/2016 at 13:01 • 0 commentsI have quite a few of the V1 PCB's printed that i did not use, as the project scope they where part of changed. If any one is interested in some for free let me know .
At this point im marking this project complete. It was part of a larger project i may document here to one day as well as a coulpe of other older and new projects.
PCB Version 2
03/14/2016 at 21:53 • 0 commentsHere is Version 2, all IO pins are brought out for easy re-purposing, the vcc ripple cap as a spot (C2) and the reed switch spacing is wider.
Version 1 Mods
03/14/2016 at 12:27 • 0 commentsHere you can see the 2 changes i made to version one to use it, a 100nF ceramic capacitor between 328 vcc/gnd to smooth power ripple, and a new entry hole for the wider magnetic reed switch i was supplied.
Bootloader & Fuses
03/14/2016 at 11:49 • 0 commentsThis is the fuse & boot loader settings for arduino boards.txt :
atmega328bb.name=ATmega328 8MHZ 1.8V BOD atmega328bb.upload.protocol=stk500 atmega328bb.upload.maximum_size=30720 atmega328bb.upload.speed=57600 atmega328bb.bootloader.low_fuses=0xE2 atmega328bb.bootloader.high_fuses=0xDA atmega328bb.bootloader.extended_fuses=0x06 atmega328bb.bootloader.path=arduino:atmega atmega328bb.bootloader.file=ATmegaBOOT_168_atmega328_pro_8MHz.hex atmega328bb.bootloader.unlock_bits=0x3F atmega328bb.bootloader.lock_bits=0x0F atmega328bb.build.mcu=atmega328p atmega328bb.build.f_cpu=8000000L atmega328bb.build.core=arduino:arduino atmega328bb.build.variant=arduino:standard
And a photo of my home made ISP burner, with interchangeable crystal:
PCB Version 1
03/14/2016 at 11:29 • 0 comments -
Prototype photos
03/13/2016 at 22:40 • 0 comments
