I am aiming to have 3 part systems with all my batteries, and ultracapacitors to allow them to be sprayed, painted, or printed in layers and create a completely modular battery system.
This will be very helpful to a large number of DIY'ers.
The system will consist of a x-axis that houses 3 peristaltic pumps. These will pump liquid out of pipettes and drop cast an anode, cathode, and seperators/electrolyte onto a heated build plate where they can be built up in series or parallel to print a battery.
The software is all pretty much completed and I believe I will be able to use slic3r and RepRapPro host to do "multicolored" prints with each of my materials.
The difficulty lies in engineering the x-axis, affording materials for this build and engineering a much larger printer. For the heated bed will be usable in different 3d printing applications it is its own project.
This documentation describes Open Hardware and is licensed under the
CERN OHL v. 1.2.
You may redistribute and modify this documentation under the terms of the
CERN OHL v.1.2. (http://ohwr.org/cernohl). This documentation is distributed
WITHOUT ANY EXPRESS OR IMPLIED WARRANTY, INCLUDING OF
MERCHANTABILITY, SATISFACTORY QUALITY AND FITNESS FOR A
PARTICULAR PURPOSE. Please see the CERN OHL v.1.2 for applicable
conditions
Can you talk more about the chemistry of the batteries you wish to print? What would be example steps using this system that would lead to a working battery?
