A concept for a small RPN processor with interesting features
emulation.zipEarly alpha version of CPU7 emulation code written in C (probably buggy)x-zip-compressed - 18.05 kB - 12/25/2016 at 12:23 |
CPU7.pdfCPU7 descriptionAdobe Portable Document Format - 410.88 kB - 03/26/2016 at 11:38 |
Although natively working with 16-bit words (14-bit pairs of instructions or data), CPU7 is also supposed to handle "raw" unformatted data in 8-bit, 16-bit, or 32-bit format. As an example that could be a hardware register, video memory, or anything which is not part of CPU7.
As a small coding exercise to test the flavour of the CPU7 assembler, here is the well known "bubble sort" of an area of unformatted bytes.
'! usage: addr len bubblesort8
:bubblesort8
dup 1 > if `! check if the array is more than one element
enter
1 over + `! calculate end=addr+len; stack: beg, end
1 swap dup `! stack: end, beg, addr
repeat
dup rd8 `! stack: end, beg, addr, [addr]
1 over ++ rd8 `! stack: end, beg, addr, [addr], [addr+1]
< if `! stack: end, beg, addr
++ `! addr=addr+1
else
2 over wr8 `! stack: end, beg, addr, [addr]
1 over ++ wr8 `! stack: end, beg, addr
drop dup `! addr=beg; stack: end, beg, addr
endif
dup 3 over < until
leave `! clean up the data stack
endif
drop drop `! remove the input parameters from the data stack
Nice project. The choice on the 7 bit is interesting. I have created a homebrew CPU also using 7 bits of data, although mine is more minimalist and designed to support functional programming.
Thank you very much for this interesting project. I've implemented most instructions of cpu7 in Verilog https://github.com/wil-low/projf-explore/tree/main/cpu/cpu7 . It was fun!
