The uROG will have following modules (ordered earlier and being evaluated now, except some like SI1144 that is not available for retail yet, but Modern Device has developed and made available a SI1143 breakout board with his own algorithm);
- Power
- Tools
- Flash Light
- Flood Light
- Laser Pointer
- Weight Machine
- Public Address System (Power Amp, Mic, Speaker)
- Remote Speakers
- Peltier based water warmer/cooler
- Moisture/Rain sensing
- Wind Speed/Direction
- Multi-meter
- Computing
- 1 GHZ processor
- 2 x 32bit PRUs
- Arduino compatible boards for remote nodes
- Input/Output
- Keyboard (I am considering "Xebec-Tech HTPC Wireless Handheld Keyboard" and a way to have wired connectivity to Beaglebone Black)
- Touch Screen TFT display
- E-Paper display for battery saving mode (Pervasive Displays ST044AS182 4.41" AURORA WT EPD W. G2, ZIF +)
- LCDs for add-on/remote modules (Bought 1x1.8" module from ebay and located a tutorial on how to interface it, it worked when I left SD card connections unused)
- Pixy CMU5 Cam
- Communication & Connectivity
- BT (2.1+4)
- ISM (XRF, ARF), I want to develop an application to enable 2 uROG gadgets to communicate and share data/coordinates with each other. I like Beartooth & goTenna concepts but found some limitations with Beartooth tech.
- Ham
- Weather Radio
- FM
- Multi Band SI4735 (MW, LW, SW, AM)
- 3G
- GSM
- IR
- Sensing
- Environmental
- Barometer
- Humidity HDC1000
- Ambient Temperature
- Sound ADMP 401
- Light (UV, IR, Ambient) SI1145
- Hazard
- Lightning Sensor AS3935
- Gas (MICS 6814) Grove I2C sensor successfully reads 8 different gases concentration.
- Radiation (Radiation Watch Type 5)
- Location & Positioning
- GPS (NAVSpark GL)
- IMU (BN0055)
- IR
- Biometric
- Bitalino
- EMG
- ECG
- EDA
- SPO2 (MICS 1144)
- Pulse
- Stretch
- IR Temperature
- Surface Temperature
- Color Sensor TCS 34725
- Bitalino
- Environmental
Software personalities; A rotary switch will be used (I am trying to find knob and switch like this one) to switch to any of following roles and a toggle to switch to another memory card containing digital forensics and penetration testing distro (Kali).
- Open Router
- VPN/VPS
- File Server
- Anon sharing of files
- Surveillance Camera (Motion)
- Wireless Gateway
- E-Book Reader
- Media Center
- VOIP Phone
- TOR
- SDR
- Machine Vision/Object Recognition
- FM Radio Station
- NW Tool
- Honeypot
- Network Scanner
- Wardriving
Lab tool
- Oscilloscope
- Logic Analyzer
- Signal Generator
- Frequency Measurement
- LE Sniffer
- TV-B Gone
- USB Tester
Noman Shah
Andrew Lamchenko
Max.K
Insight Machines Lab
Mirko
Something new here ??? :-))
