- Boxes․py is an online box generator
- Boxes․py is an Inkscape plug-in
- Boxes․py is library to write your own
- Boxes․py is free software licensed under GPL v3+
- Boxes․py is written in Python 3
Boxes․py comes with a growing set of ready-to-use, fully parametrized generators. See https://florianfesti.github.io/boxes/html/generators.html for the full list.
Features
Of course the library and the generators allow selecting the "thickness" of the material used and automatically adjusts lengths and width of joining fingers and other elements.
The "burn" parameter compensates for the material removed by the laser. This allows fine tuning the gaps between joins up to the point where plywood can be press fitted even without any glue.
Finger Joints are the work horse of the library. They allow edges and T connections. Their size is scaled up with the material "thickness" to maintain the same appearance. The library also allows putting holes and slots for screws (bed bolts) into finger joints, although this is currently not supported for the available generators.
Dovetail joints can be used to join pieces in the same plane.
Flex allows bending and stretching the material in one direction. This is used for rounded edges and living hinges.
Documentation
Florian Festi
Jeremy
phryk
blorgggg
I have plans for a Savonius 4-blade design fan for wind powered generation. You could possibly make a generator code for it? I used your FlexTest generator to make the blades. it's simple enough. If you want the SVG file I can send it to you?
