Boxes.py
Cut out boxes and other stuff with a laser cutter
An (Online) Box Generator for laser cutters.
  • Boxes․py is an online box generator
  • Boxes․py is an Inkscape plug-in
  • Boxes․py is library to write your own
  • Boxes․py is free software licensed under GPL v3+
  • Boxes․py is written in Python 3
Boxes․py comes with a growing set of ready-to-use, fully parametrized generators. See https://florianfesti.github.io/boxes/html/generators.html for the full list.
Features
Of course the library and the generators allow selecting the "thickness" of the material used and automatically adjusts lengths and width of joining fingers and other elements.
The "burn" parameter compensates for the material removed by the laser. This allows fine tuning the gaps between joins up to the point where plywood can be press fitted even without any glue.
Finger Joints are the work horse of the library. They allow edges and T connections. Their size is scaled up with the material "thickness" to maintain the same appearance. The library also allows putting holes and slots for screws (bed bolts) into finger joints, although this is currently not supported for the available generators.
Dovetail joints can be used to join pieces in the same plane.
Flex allows bending and stretching the material in one direction. This is used for rounded edges and living hinges.
Documentation
https://florianfesti.github.io/boxes/html/index.html
  • Boxes.py back online
    Florian Festi • 7 days ago • 0 comments
    Our website and Boxes.py are back online. Many thanks to all the unsung heros that keep our civilization running!
  • Online Generator Temporarily Offline
    Florian Festi • 11/19/2026 at 07:14 • 0 comments
    Due to the  current nginx woes the Online Generator is offline for now. Service is assumed to continue as soon as our administrators get to updating the infrastructure of our hackerspace. Understand that they have to attend to other, more import things first. In the mean time you can run Boxes.py locally. You can either build a Docker image from the sources, download the latest image from GitHub or run Boxes.py directly from the sources in a Python virtual environment.
  • A (simple) Donation Box...
    Florian Festi • 08/31/2025 at 09:39 • 2 comments
    Sometimes a box is just a box. Sometimes things escalate.
    In passing the stage manager of the local string puppet theater mentioned she still has to order a donation box before their summer party. Surely we can help here and laser cut a nice box - may be with the logo engraved.
    (Un)fortunately my wife and I had a bit of time at our hand to brain storm how such a box should look like. It really needs a string puppet. And the string puppet actually needs to bow when money is entered. May be have a lever that needs to be pulled and if some money has been inserted that could then make the puppet bow. But what about bank notes.... and sound... and light...? If we needs some contraption that makes the string puppet bow we need a stage to attach the strings to. But then we need lights and then we need power and then we can just use a micro controller... right?
    Luckily there were a few other donation boxes build in our hackerspace at the same time for the "kontakt" festival. These look very different from what we had in mind. They were boxy with an acrylic front and a lot of blinking LEDs - which is fine for a music festival. But the electronics looked promising: ESP32 with a light barrier for the money slot, LED stripes and rings for light and a MP3 module for sounds. That not only meant we already had a prototype for the electronics but we could also "borrow" most of the components from the people building the festival donation boxes. Having a micro controller also means movement can be easily done with a small servo.
    With a good idea on the electronics  it was time to decide on the shape of the donation box. It as very clear early on that a puppet would need a stage. And the stage could only be THE stage. A model of the about 200 year old original stage that the theater is still using. The stage that is the reason the theater even exists:
    So we visited and took pictures from the stage two sets of scenery. Yes, the stage has multiple layers of scenery that will be changed between scenes and even slots for special effects like flame paper - although we were not going to replicate those. It also has an orchestra in multiple rows, even if the musicians are only static cutouts.
    So we need a box where we can put the scenery in. Luckily there just was one added to Boxes.py recently: The NightLightBox by gpsqueeek. It needed some minor adjustments for this to work but it could be used mostly as is with a bit unusual settings.
    The NightLightBox of course doesn't have room for money to be inserted. I refrained from creating a purpose built box generator but decided to just combine existing boxes. For the money box the SlidingDrawer was an obvious choice. Just adding a mail box lock and a slit on top was all that was needed besides the electronics. For the electronics there is the *surprise* *surprise* ElectronicsBox this time without mounting tabs and just clued underneath the stage. A second box fills the remaining space on the bottom and offers storage for a power bank.
    Making the string puppet bow turned out to be  a bit more difficult. While there is a special bow string (not this kind of bow string) it is just to hold the bottom of the puppet up. There is still a string for the head and two wires for the shoulders that need to move. Then there are the strings for the hands that might need handling, too. Otherwise the arms just hang down from the shoulders which doesn't looks very graceful.
    But if everything you have is a hammer everything looks like a ... box. So I created a box that represents the torso of the puppet and all strings can be attached to the corresponding places. Then just tilting the box at the "hip" makes the puppet bow. The strings for the arms can just be fixed in place so the arms stay on the side of the torso. The stiffness of the fabric even makes them move outwards a bit which looks ... intended.
    To gain a bit of height and make assembly and testing easier the box was put into...
  • New Live Preview
    Florian Festi • 03/23/2025 at 10:20 • 0 comments
    I have been travelling without my laptop for two weeks lately. Mainly to reduce screen time. Of course this didn't work. So I browsed the internet on my phone for tutorials, reviews and videos on Boxes.py to get a better idea on how it is used and perceived by its users. To my total shock not everyone seems to agree with the obvious fact that Boxes.py is the very best box generator.
    People are having problems with the complexity of the UI and are overwhelmed by all the options and the number of generators. It's not that I didn't know that in principle. But seeing it "in person" hits differently. It's also not the first time this topic has come up. The "new" gallery style front page was implemented to give a quicker overview - especially to new users.
    More Guidance?
    My first idea was creating a "Guided Tour"; may be as a video, just the web page and a voice over. The basic things can all be explained with ABox, the most basic generator in Boxes.py,  which is still more complicated than some other simple box generators elsewhere. One the could continue to the UniveralBox, TypeTray, an overview of all generators. But I have never really done a video, don't have a YouTube channel. So this is a whole can of worms I am not quite ready to open.
    Also it means admitting that one basically needs a lecture before being able to use Boxes.py. What's next? A Boxes.py bachelors degree?
    Previews
    Some other - here unnamed - box generators do have previews. Some show the 2D drawing, some even have a 3D rendering. The later is out of the question for Boxes.py. Boxes.py is a combination of turtle graphics and argparse - both stretched beyond their natural limits. It is as 2D as it can be and assembling the pieces into 3D space is more work than the project has received so far.
    A 2D preview on the other hand is not that hard to do. Funny enough there actually was a place holder for it in one of the earliest versions of the web interface. But for some reason this has never materialized - until now.
    Implementing it was a lot easier than I expected. What took quite a bit was getting the CSS right to one can zoom in and out while still keeping the 100% view dependent on the actual size of the drawing. Enabling the "outside" checkbox does change the size of the box. Scaling the drawing to the same size as before hides this and is likely to confuse users more than it actually helps. On the forth or fifths try it finally did what I wanted.
    User Experience?
    So the new live preview is online for a while now already. Does this actually help? Does it make it easier to understand what the settings do? Or makes it the UI worse? Are there still things you don't understand?
  • Giving something back?
    Florian Festi • 02/11/2025 at 19:37 • 0 comments
    For most of the first decade of Boxes.py I didn't even think about monetizing the project. To be fair: After the project's start I was without a laser cutter for almost two years and nothing was happening anyway. Even when development was going again and the topic came up, I wasn't interested. This was a just for fun project and nothing I wanted to turn into a job or side hustle. Also it is my personal contribution to the Open Source community in general. Yes, I very much understand that many projects are nowadays sponsored or driven by corporations or large organizations, but I like to pretend that most Free Software is still held up by single contributors like myself and each of us is adding their share.
    Anyway, the last years requests for a way to donate money have become more frequent. Beside my general hesitation it also required setting up the web instance properly from a legal POV. Being located in Germany that meant getting an Impressum and all the DSGVO declarations (the German implementation of the EU's GDPR). All topics I am just as interested as getting a hole drilled into my knee. As a result not much happened except people opening a ticket and me pointing them to the very brief and also German only page of Boxes.py on my hackerspace's web page. This had (and still has) a simple PayPal link as part of the project template.
    While this was just meant as a temporary fix, it made it clear to me, that I don't want donations to me personally at all. Even more so now with the huge amount of 3rd party contributions. It would be really weird to showcase all this work from other people and then turn around and say "Please give me money ". I realized that my hackerspace (backspace e.V. in Bamberg,  Germany) might be a possible place to direct donations to even long term. But it still felt a bit arbitrary. Like why would you care for a random hacker space in Upper Franconia which may be or may not be on the other end of the world from you.
    But things changed last year. My hacker space started hosting the web instance after the virtual server running it previously had more and more problems. This now allows me to just reuse the legal stuff from there. It also makes a lot more sense now to point donations in that direction. As a German nonprofit ("gemeinnütziger Verein") it also can accept donations easily without creating paper work for myself.
    So over the new year's break I did not only write the retrospective but also resurrected previous efforts of getting a donation page done. Then I realized that no one would see it anyway - with all the links being at the bottom of the page. So a little bit of rearranging later the help and documentation and the language selection can now actually be found. Guess that alone makes this all worth it.
    So here we are. There is now a Give back link on the website. Should you go there? Yes, yes you should. Should you donate some money? Probably not. There are a lot of better causes to donate money to. Does it still feel good if people show their appreciation and the value they get from Boxes.py this way? Oh yes, yes it does.
    So to everyone who has donated already: Thank you very much!
  • Looking back at 2024
    Florian Festi • 12/22/2024 at 21:56 • 1 comment
    ... and a bit beyond. 2024 is at its end. Time to have a look back and see what has happened in the project.
    End of 2023
    Still back at the end of 2023 I added two generators on popular requests.
    SkadisBoard, simple version of the IKEA storage system with the same name. There currently are no generators for anything that attaches to the board. Maybe the WallMounted series could grow an option for that.
    An "urgent need" in our hacker space was better pizza handling. PizzaShovel does just that. It uses a conveyor belt action that is kinda magical. It sneaks its way under the pizza without it needing to slider over the surface. I had seen this years ago as an industrial handling device that can even pick up a blob of ketchup and place it down just the way it was. Pizza is not quite as challenging but raw dough is not trivial move around either.
    Boxes with a mission
    First project actually in 2024 was the AirPurifier I did on collaboration with MachineryEnchantress Naomi Wu. It's a simple box with a filter or two and a few PC fans:
    It is the first in a long list of boxes with a few features added to turn them into something else - even if they are still very boxy at heart.
    A very beautiful example is ojensen5115's CoinBankSafe. It's "just" a box with a hinged lid. But dials and a slit on top make it into a very nice piggy bank. The "lock" is simple but just fine for this purpose. There is a future project to upgrade to a proper combination wheel for someone.
    The BrickSorter by fidoriel turns boxes into a set of sieves to sort your favorite building blocks.
    A DiceTower has been on my ToDo list for a long time. But there are so many options and possible features: a bowl to catch the dice, a lid so it can be used as a dice container, may be have the catching bowl be detachable to you can toss the dice back in with it, ...
    I never could bring myself to just do the simplest possible solution - just a box with a few angled walls within. Thanks to tljuniper for doing just this.
    ZBeam by jasondunsmore is meant as a cable channel with a mounting tab. It also offers a U channel option. It is basically the continuation of the LBeam by the very same means.
    Storage Solutions
    Storing things and especially small objects is the bread and butter of Boxes.py. There are quite a few new options in this area. But a good portion are variants of other generators.
    The GridfinityDrillBox is just the normal DrillBox but rehashed for the Gridfinity system. This is something one could probably been able to do before by carefully selecting the sizes and gluing on the the foot pad. With this generator this is much easier. These drills look a bit funny, though...
    The BinTray has been around for quite a while. But it is meant to be stationary.  pkochubey took the idea and combined it wit the Stackable Edge to get these beautiful and very useful StackableBins.
    AlexCPU adjusted it to get it into the WallMounted group as WallStackableBin - allowing it to be hanged on a French cleats or slat wall.
    But he was not quite finished with the whole bin idea and created the WallHopper for even more storage space. I wonder if screws really is the best use of this when one could just as well put some candy in.
    WallRack is a bit of an odd one as it is not part of the regular WallMounted crowd that supports slat wall and French cleats etc. It instead sports just mounting holes for screws. Still a handy little storage solution that does not quite come with the complexity of the TypeTray configured for wall mounting.
    J-Waal's  CompartmentBox is a blend of the TypeTray and the CardBox offering a sliding lid over a grid of compartments.
    HobbyCase that JGrzybowski did for Hacktoberfest is a very nice storage solution for everything than needs many small pieces that need...
  • New Server!
    Florian Festi • 05/13/2024 at 20:25 • 0 comments
    As people surely have noticed the web instance was pretty slow at times. The issue was not really too much load but some weird latency or time out problem. As my hackerspace has setup a new server I asked if they would host Boxes.py. So now a new instance is available at https://boxes.hackerspace-bamberg.de. I added a redirect to the old location so you end up there no matter what. For now this is still in testing. Please report any issues you have here or on the GitHub project. If everything works out fine I will change all the links to the new instance.
    Update: Looks like everything is working fine. I switched over the URL in all places I could think of. So the web instance is now officially move to its new home. Please enjoy the much quicker response times!
  • Personal Backlog
    Florian Festi • 03/08/2023 at 23:13 • 1 comment
    Being able to put more time into the project have I looked into my local repository and it is full of half finished projects - most of them new "box" generators. I have been working on getting some of them in shape for inclusion. Additionally there where a few needs that popped up that also needed instant addressing. Funny enough a lot of these new generators come in pairs.
    So I did a roll holder for the kitchen after the old, 3D printed one broke:
    Well, it is mounted to the wall... so a "Wall" variant was needed:
    After finishing both I found another 20% finished holder in my working dir. It is more ambitious with 3 layers on each side that allow locking in the axle by rotating the middle layer. No idea why that didn't get finished. May be one day the two above get a fancy sibling...
    For another project I need to 3D print a small part (yes, I know, heresy) but the filament didn't come with it's own spool. So, I did a spool that can be separated into two parts using the BayonetBox as a basis:
    And as I was at it it was just too easy not the strip it down to a one piece spool (and then add some fancy reinforcements):
    One generator I started a long time ago was one for generating Tetris blocks. At the time this wasn't that easy and quite a bit of work. Nowadays this is much easier as we have the polygonWall method that gets a list of lengths and angles and handles the rest. There also is a companion method to create all the side walls from the same list. So the only tricky part was getting the lengths right as we do want the walls to be within the perimeter of the block structure. I am optimistic they fit, but I have not yet cut them out. So if you feel adventurous and "need some Tetris blocks in your life" please donate a few good pictures.
    Another "thing" that I started long ago and started over with more than once is my Seven Segments feature. The idea is to use a LED stripe on its side and wind it through the seven segments. So you can create a seven segment display without much soldering or special circuit boards and from semi small to quite big. The obvious use case is a seven segment clock. Both of them are still flagged "unstable". But I am not sure if I get to build one any time soon. So if one brave soul is looking an LED stripe fueled clock project let me know.
    So far my backlog is all but empty and I still have more ideas. I just started with a wire straightener holding two rows of v-groove ball bearings. I have a cryptic font that is mostly finished with each letter is just a few shapes that are only legible when surrounded by a border. I wanted to create a calendar with them, preferably perpetual or even some clever mechanical one. I saw a cube box at the Fablab of the University of Oulu that is cut directly between pieces without creating gaps. And I have a half working one for arbitrary sizes.  I have toyed a bit with flexures and thought about doing a laser cut microscope like the OpenFlexure Microscope although with very different kinematic. And I have a dozen more that are not much more than the first few lines of code and I am not confident enough to publicly admit here.
  • Old News and New News
    Florian Festi • 02/17/2023 at 10:43 • 0 comments
    It's been a while since the last proper log entry...
    The last few years were not that great for many things - including Boxes.py. But even with things going slow or not moving anywhere for months a lot of changes have piled up over this long time. Also it looks like this year is a lot better and things have actually already picked up speed in December of last year. Not only have I been able to do more but several old and new contributors have shown up and gave the project a very notable boost. To deal with the long backlog of new features and box generators while there is so much new stuff coming in I decide to mix in the old with the new.
    Wall Mounted Boxes and Tool Holders
    After a brief discussion here in the comments in early 2022 I factored and renamed the SlatWall group to WallMounted. While slat walls are fancy not many people have them. The whole group is only there because a few panels fell into the hands of our hacker space. Now the generators can have different styles of hooks and also work with DIN rails or French Cleats. It is relatively easy to add new ways of hooking the boxes and tool holders to different things. So it you have ideas open a ticket on GitHub - or start a discussion in the comments below.
    There are also few new generators in this group:
    • SlatWallPinRow allows you to hang stuff on the wall.
    • WallStairs allows you to design your own tool holders.
    and I recently added a few more sample images.
    On the search for the right box generator
    Caleb Crome is one of our new and very prolific contributors. One theme of his work is making finding the right box generator easier. He wrote a Gallery page that shows all sample images side by side for a quick overview.
    The second, complementary new feature is a search field on the menu page. It shows all matching box generators and matches the English name but also the translated name and short description. This is all done with some - not even too complicated - Java Script magic directly in the browser.
    A third feature is not merged yet. It will allow getting or adding QR codes with a link and settings of a generated box. That way it is easier to pass the settings around with a mobile phone or to figure out how to get the drawing from an already laser cut piece.
    These new features are not all Caleb has done so far. Prepare to hear more from him as soon as we get into new generators.
  • Server Health Improvements
    Florian Festi • 01/09/2023 at 15:35 • 0 comments
    The last few months complaints about poor performance and an increasing number of 502 errors have been piling up. The later were especially puzzling as it means there is a problem in the communication between the web server and uwsgi instance in the container. While there was some load on the machine everything looked fine at the first glance and there was nothing in the logs that hinted at a bug.
    At the same time there were similar complaints for the web2py application that runs on the same machine. Well, actually this thing is a VM that runs on a server of a friend of a friend that does a few other things and is only maintained to the bare necessity. When I put Boxes.py there the question I asked myself was not "How do I host the greatest box generator on the internet?" but "Now that I hacked argparse to produce web pages how can I show this to a few people?"
    Over the holidays I had time to look a bit deeper. Turns out the web2py app offers the data with different sorting and filtering and a horde of web crawlers eating it all up. Adding a robots.txt got rid of them and dropped the load from 0.7 to below 0.1. I may loosening this up a bit in the future but for now I just banned bots completely - including from Boxes.py.
    Looking at the logs from Boxes.py it was very apparent that there are even more connections coming in. Most of them of course are these nice pop-up images in the menu. While I still didn't have access the the main machine it dawned on me that the Boxes.py instance probably gets throttled down due to too many request. This would create timeouts and though the 502 errors. To fix that I moved all the pictures to the GH (documentation) pages and adjusted the links to point there. As this would be very annoying for people that run Boxes.py locally (me) this change affects the wsgi mode only. Yes, the boxesserver should grow a config file for things like that but I just couldn't be bothered.
    So performance has notably improved and I hope you all can now create your boxes without seeing 502 error messages. Looking into the access log it turns out there are quite  a lot of you. There are tens of thousands of request per day - even with the pictures moved elsewhere. This is kinda cool but also kinda scary...
View all 62 project logs
alanpassmore wrote 02/23/2026 at 21:39 • point
I have plans for a Savonius 4-blade design fan for wind powered generation. You could possibly make a generator code for it? I used your FlexTest generator to make the blades. it's simple enough. If you want the SVG file I can send it to you?
Florian Festi wrote 02/24/2026 at 08:42 • point
I wonder if flex is really is a good choice from a mechanical and aerodynamic POV. Feel free to link your Hackaday project here.
bbunch1970 wrote 06/01/2025 at 23:20 • point
did another project the coffee pod rack, changed up how it is done as it is free standing for a market display and set to put in with label out at the bottom to see and  pod out above it to grab and pull out.  but did have to monkey with sizes, seems to import right, I think the project just needs variables for the 2 diameters of the pod, likely not all pods the same.    https://img.mewe.com/api/v2/photo/Mkzmm7g_wNnvEMoRVFUtCf1kGbtk-KB9ByZ0QJwMjl1oO7gNW8eKc0Wjmvw/800x800/img?static=0
Florian Festi wrote 06/02/2025 at 07:08 • point
This link doesn't seem to be public.
Adding the diameters shouldn't be too complicated.
bbunch1970 wrote 06/02/2025 at 09:35 • point
https://static-assets-1.truthsocial.com/tmtg:prime-ts-assets/media_attachments/files/114/613/083/860/433/322/original/374733b4164341c5.jpg
Florian Festi wrote 06/02/2025 at 16:55 • point
Ok, added the parameters, just in case.
The build looks pretty nice and sturdy. If you are still getting uniform hardware I would try coach bolts.
bbunch1970 wrote 05/04/2025 at 21:17 • point
modified the paper towel holder into a tp holder, would like to upload pictures, basically instead of loops to support the rod I did holes for a spring loaded tube.  If the permissions allow you can try https://static-assets-1.truthsocial.com/tmtg:prime-ts-assets/media_attachments/files/114/451/500/768/926/109/original/9af0c96623efe705.jpg
Florian Festi wrote 05/05/2025 at 13:16 • point
Very neat! I also very much agree with your sentiment!
Jay.perez1 wrote 04/21/2025 at 16:59 • point
Incredibly powerful and capable box generator !
Thank you for your hard work and dedication to this project !!!
I just noticed there's an output directly to a Lightburn file format. Is that new ?
Jay
Florian Festi wrote 04/21/2025 at 20:43 • point
Thanks!
The Lightburn format got added a bit more than 3 years ago:  https://github.com/florianfesti/boxes/pull/375
...and not by me.
geoffreymbaker wrote 01/28/2025 at 19:39 • point
Hi, I made a set of 6x6 trays with removable dividers just editingthe svg file in Illustrator. Is this something someone has built into the code yet?
Florian Festi wrote 02/03/2025 at 15:40 • point
There is https://boxes.hackerspace-bamberg.de/DividerTray
If yours is significantly different it might be worth opening a ticket on GitHub and attach a picture and your SVG file there. Link is on the left.
uɐᴉʇǝqɐZ pnoqɥɐW wrote 09/10/2024 at 19:24 • point
Hello and thank you for this great project. I need to figure out how to make small-ish changes to some of your boxes, as I feel like it would be useful for others. Is there a demo/tutorial someplace that can show me how I can make changes and get to the point of a PR?
For example, you have a NotesHolder box ( https://boxes.hackerspace-bamberg.de/NotesHolder ). I use that to make a larger box for giving away postcards about my business. I make the back side taller so I can have a message on it, and people walking by can take a postcard out of it if they wish. The change I want to make is to have the back side's height to be customizable. If there is no tutorial for doing something like this, I can try to create one, but I first have to learn how to make this change.
Florian Festi wrote 09/11/2024 at 20:43 • point
Often the easiest way is to just generate the "box" as is and then alter it with a vector graphics program like Inkscape. Just move the top corners of the part up and be done with it.
If you really want to extent a box generator there is documentation at https://florianfesti.github.io/boxes/html/index.html (linked at the bottom of the web instance). https://florianfesti.github.io/boxes/html/api_examples.html gives a few starting points and https://florianfesti.github.io/boxes/html/apidoc.html explains the API.
uɐᴉʇǝqɐZ pnoqɥɐW wrote 09/11/2024 at 21:54 • point
Thank you for replying. I use Affinity Designer to add what I need. One problem is that I have different types of wooden sheets, with different thicknesses, and when I change the thickness, I have to reapply all my other changes.
If my request doesn't seem like it would benefit others, then I'd probably stick to what I am doing. Otherwise, if it makes someone else happy, then I get my own needs met too!
I'll look at the links you mentioned. Thank you.
david roseman wrote 09/02/2024 at 14:00 • point
Good day!  Awesome site.    When I create a "box" and it includes the settings URL, when I go to that link in LB, it just takes me to the bamberg.io main page.  I'm using Chrome and Firefox.
Florian Festi wrote 09/11/2024 at 13:10 • point
OH, indeed there is a /boxes.py/ in the URL that does not belong there. This is a leftover from the previous location the web instance was running. I'll try to get rid of this. For now you can just drop that part from the beginning of the path.
Florian Festi wrote 09/11/2024 at 19:58 • point
Fixed now. Thanks for reporting!
bbunch1970 wrote 08/14/2024 at 16:07 • point
What would be handy is to be able to build a box to go between 2 custom ends, lets say you make two elephant ends and want to put 2 sides and a bottom between them (my thought is to use acrylic and make flower pots) so you would generate the 2 sides and bottom of the box, and a set of holes to add to your custom ends to be able to assemble it.  on that same train of thought, I haven't looked at the options yet but what I would like to do working with acrylic is to have the tabs stick out slightly to flatten with a heated tool, sort of like flattening off rivets to hold it together.  I suppose you could fudge the thickness to make that work though.
Florian Festi wrote 08/27/2024 at 17:23 • point
You already can use a UniversalBox and select "finger_holes" for vertical_edges and "h" as bottom_edge. If you don't like the finger holes on the front and back you can re-generate the box with "F" as bottom_edge and take the sides (y direction) from there.
david roseman wrote 09/11/2024 at 16:07 • point
Thanks!!
Keith wrote 05/16/2024 at 15:25 • point
Would be very nice if you could add to ABox a setting to change the material thickness for the bottom, independently of the rest of the box. When using 12mm material, it is not necessary to use 12mm also for the bottom. Cheers
Yaroslav Zaklynskyi wrote 02/10/2024 at 19:02 • point
Hi, thank you for the great job you did!
The generator does the job.
Today I used it to create a kind of box rig to place the external laptop monitor on it.
It would be awesome to have a live preview mode to understand how the different options affect the result. It takes some time to generate a new preview, download, and check it (or open in a new tab).
Thanks again!
Florian Festi wrote 02/15/2024 at 20:38 • point
The Inkscape plugin has a preview if you can get that to work. You might not, though. But you can try MightyScape: https://gitea.fablabchemnitz.de/FabLab_Chemnitz/mightyscape-1.2
zifnab69 wrote 12/17/2023 at 16:41 • point
I have a bug in the box generator. Where can i send photos of the problem ?
thank you
Florian Festi wrote 12/23/2023 at 10:21 • point
Please open an issue in the GitHub project (Top link on the left side). You can attach images there. But adding the link to the result is often even more helpful.
meximedia0 wrote 11/02/2023 at 00:24 • point
hi im very glad with the proiect, and i have an ask, i want to know if is possible add a optoion to make a 3d boxes like letters or figures
Florian Festi wrote 12/23/2023 at 10:32 • point
There isn't something finished yet. I do have an unfinished generator for letters locally but it only has the simple letters and is still missing quite a few letters.
On an API level there is polygonWall() that allows you to draw a shape from lines and arcs and polygonWalls() that draws the walls between the front and back shape.
See https://florianfesti.github.io/boxes/html/boxes.html#boxes.Boxes.polygonWall or the HeartBox as an simple example https://florianfesti.github.io/boxes/html/generators.html#heartbox
Jonruiter wrote 09/03/2023 at 22:52 • point
I am having a problem with the TrayLayout designs - the holes in the bottom panel are not big enough to fit the fingers from the interior dividers.   All the edge fingers fit well, but not so on the bottom panel.  Is anyone else seeing this?
Florian Festi wrote 12/23/2023 at 10:34 • point
If they are too narrow your material thickness and/or burn correction is not correct. Especially the material thickness won't show up on edge finger joints. Make sure to measure your material and don't rely on the nominal value.
cehugues wrote 08/31/2023 at 11:16 • point
bonjour
tout d'abord merci pour ce site qui permet de faire beaucoup de création.
je souhaiterai proposer une amélioration sur le site,
ça serrai bien de pouvoir générer une boite ronde en bois flexible avec un couvercle,
Florian Festi wrote 12/23/2023 at 19:28 • point
Not 100% sure what kind of box you are looking for but there is the RoundedBox (https://florianfesti.github.io/boxes/html/generators.html#roundedbox). It still needs two straight sections of side wall to hold bottom and top together, though.
nilouth wrote 08/27/2023 at 08:38 • point
can anyone explain to me why I am getting an <_io.TextIOWrapper name='/var/folders/9h/65ctz95j25g6fypfgby_mr400000gn/T/boxes.py-inkscapeuzvdb729.svg' mode='r' encoding='UTF-8'> error whenever I try to generate a box ? (running on MacOS Ventura w/ innkscape 1.3)
Florian Festi wrote 08/31/2023 at 09:24 • point
For everyone wondering: Issue was that boxes_proxy.py didn't didn't find the boxes executable - probably due to the PATH variable not being passed by Inkscape. Hard coding the the path of the boxes utility in boxes_proxy.py "fixed" the issue.
beaver.cavern wrote 04/05/2023 at 12:44 • point
There seems to be a error in the DisplayShelf generator. The Shelf and Front Shelf are 2 wood thickness too long. In my design I had no shelf division, may be that is a lead to look into.
Florian Festi wrote 04/06/2023 at 20:22 • point
Did you check the "outside" box?
beaver.cavern wrote 04/06/2023 at 20:53 • point
I did. I should have mentioned that the wall and tray width were different by the amount of two panel thickness.
Also looking at the generated panels, the width different is noticeable. Can I send you the QR code?
Florian Festi wrote 04/07/2023 at 08:38 • point
You can just post the link to the generated SVG here.
Edit: Ok, found it. The "outside" correction just does nothing. I was going to change the generator to use a sx parameter anyway to allow for arbitrary sections. Will fix this while doing that.
Edit2: OK; this was just too easy to fix. Should work now.
Edit3: Uses sx param now. Was all a lot easier than I thought.
beaver.cavern wrote 04/07/2023 at 15:47 • point
Thanks for the correction
datazaShane wrote 03/30/2023 at 08:08 • point
Is it possible to include a template for making an open-top box with slanted sides?
Either all sides have the same angle or each side has a different angle.
Florian Festi wrote 04/01/2023 at 17:42 • point
There was not. I just finished up https://github.com/florianfesti/boxes/pull/150 which allows to turn the RegularBox into a pyramid stump. It's not tested yet. If you feel brave you can try it out and report back. May be even attach a pictures at https://github.com/florianfesti/boxes/issues/140
Matthiasheyer89 wrote 03/14/2023 at 11:37 • point
Is it Possible to make a Template to get Pyramids or truncated pyramid (or UpsideDown trun. Pyramids) for like Vases oder Pencil Holder. Closed and/or with different bottom Joints.
Florian Festi wrote 03/15/2023 at 21:31 • point
There currently isn't. IIRC there is still an issue with finger joints with acute angles. There actually is a PR for the RegularBox that I haven't touched in much too long.
Florian Festi wrote 04/08/2023 at 09:16 • point
With https://github.com/florianfesti/boxes/pull/150 now finished RegularBox can be turned into a pyramid stump.
tim wrote 02/14/2023 at 12:37 • point
i am wanting to make a teared display stand, similar to the drill stand in misc, but shelves set at the same depth. sort of a hybrid between drill stand and display shelf,. is this possible?
Florian Festi wrote 02/14/2023 at 13:49 • point
Have a look at the WallStairs generator in WallMounted. That's not quite what you are asking for but probably the closest.
An alternative could be using a DrillStand and glueing shelves on top - may be even L-Beams from "Parts and Samples"
Florian Festi wrote 02/14/2023 at 13:59 • point
If those options aren't good enough please open a ticket on GitHub with a description and (if possible) a sketch. Pencil scribbles are good enough.
tim wrote 02/15/2023 at 01:44 • point
awesome! Thank you very much for your reply and suggestions! I'll give it a crack today!
noel hanback wrote 02/14/2023 at 02:07 • point
Heart box generator broken, no matter what measurements are used you get:
 "An error occurred! list indices must be integers or slices, not float"
Florian Festi wrote 02/14/2023 at 13:44 • point
Fix in polygonWall: Make sure callback indexes are int
Also fixed placements of the heart parts.
