- Boxes․py is an online box generator
- Boxes․py is an Inkscape plug-in
- Boxes․py is library to write your own
- Boxes․py is free software licensed under GPL v3+
- Boxes․py is written in Python 3
Boxes․py comes with a growing set of ready-to-use, fully parametrized generators. See https://florianfesti.github.io/boxes/html/generators.html for the full list.
Features
Of course the library and the generators allow selecting the "thickness" of the material used and automatically adjusts lengths and width of joining fingers and other elements.
The "burn" parameter compensates for the material removed by the laser. This allows fine tuning the gaps between joins up to the point where plywood can be press fitted even without any glue.
Finger Joints are the work horse of the library. They allow edges and T connections. Their size is scaled up with the material "thickness" to maintain the same appearance. The library also allows putting holes and slots for screws (bed bolts) into finger joints, although this is currently not supported for the available generators.
Dovetail joints can be used to join pieces in the same plane.
Flex allows bending and stretching the material in one direction. This is used for rounded edges and living hinges.
Documentation
Florian Festi
Jeremy
TraceSpazer
blorgggg
did another project the coffee pod rack, changed up how it is done as it is free standing for a market display and set to put in with label out at the bottom to see and pod out above it to grab and pull out. but did have to monkey with sizes, seems to import right, I think the project just needs variables for the 2 diameters of the pod, likely not all pods the same. https://img.mewe.com/api/v2/photo/Mkzmm7g_wNnvEMoRVFUtCf1kGbtk-KB9ByZ0QJwMjl1oO7gNW8eKc0Wjmvw/800x800/img?static=0
