Boxes.py
Cut out boxes and other stuff with a laser cutter
An (Online) Box Generator for laser cutters.
  • Boxespy is an online box generator
  • Boxespy is an Inkscape plug-in
  • Boxespy is library to write your own
  • Boxespy is free software licensed under GPL v3+
  • Boxespy is written in Python 3
    Boxespy comes with a growing set of ready-to-use, fully parametrized generators. See https://florianfesti.github.io/boxes/html/generators.html for the full list.
    Features
    Of course the library and the generators allow selecting the "thickness"
    of the material used and automatically adjusts lengths and width of
    joining fingers and other elements.
    The "burn" parameter compensates for the material removed by the laser. This
    allows fine tuning the gaps between joins up to the point where plywood
    can be press fitted even without any glue.
    Finger Joints are the work horse of the library. They allow edges
    and T connections. Their size is scaled up with the material
    "thickness" to maintain the same appearance. The library also allows
    putting holes and slots for screws (bed bolts) into finger joints,
    although this is currently not supported for the available generators.
    Dovetail joints can be used to join pieces in the same plane.
    Flex allows bending and stretching the material in one direction. This
    is used for rounded edges and living hinges.
    Documentation
    https://florianfesti.github.io/boxes/html/index.html
    • Giving something back?
      Florian Festi02/11/2025 at 19:37 0 comments
      For most of the first decade of Boxes.py I didn't even think about monetizing the project. To be fair: After the project's start I was without a laser cutter for almost two years and nothing was happening anyway. Even when development was going again and the topic came up, I wasn't interested. This was a just for fun project and nothing I wanted to turn into a job or side hustle. Also it is my personal contribution to the Open Source community in general. Yes, I very much understand that many projects are nowadays sponsored or driven by corporations or large organizations, but I like to pretend that most Free Software is still held up by single contributors like myself and each of us is adding their share.
      Anyway, the last years requests for a way to donate money have become more frequent. Beside my general hesitation it also required setting up the web instance properly from a legal POV. Being located in Germany that meant getting an Impressum and all the DSGVO declarations (the German implementation of the EU's GDPR). All topics I am just as interested as getting a hole drilled into my knee. As a result not much happened except people opening a ticket and me pointing them to the very brief and also German only page of Boxes.py on my hackerspace's web page. This had (and still has) a simple PayPal link as part of the project template.
      While this was just meant as a temporary fix, it made it clear to me, that I don't want donations to me personally at all. Even more so now with the huge amount of 3rd party contributions. It would be really weird to showcase all this work from other people and then turn around and say "Please give me money ". I realized that my hackerspace (backspace e.V. in Bamberg,  Germany) might be a possible place to direct donations to even long term. But it still felt a bit arbitrary. Like why would you care for a random hacker space in Upper Franconia which may be or may not be on the other end of the world from you.
      But things changed last year. My hacker space started hosting the web instance after the virtual server running it previously had more and more problems. This now allows me to just reuse the legal stuff from there. It also makes a lot more sense now to point donations in that direction. As a German nonprofit ("gemeinnütziger Verein") it also can accept donations easily without creating paper work for myself.
      So over the new year's break I did not only write the retrospective but also resurrected previous efforts of getting a donation page done. Then I realized that no one would see it anyway - with all the links being at the bottom of the page. So a little bit of rearranging later the help and documentation and the language selection can now actually be found. Guess that alone makes this all worth it.
      So here we are. There is now a Give back link on the website. Should you go there? Yes, yes you should. Should you donate some money? Probably not. There are a lot of better causes to donate money to. Does it still feel good if people show their appreciation and the value they get from Boxes.py this way? Oh yes, yes it does.
      So to everyone who has donated already: Thank you very much!
    • Looking back at 2024
      Florian Festi12/22/2024 at 21:56 1 comment
      ... and a bit beyond. 2024 is at its end. Time to have a look back and see what has happened in the project.
      End of 2023
      Still back at the end of 2023 I added two generators on popular requests.
      SkadisBoard, simple version of the IKEA storage system with the same name. There currently are no generators for anything that attaches to the board. Maybe the WallMounted series could grow an option for that.
      An "urgent need" in our hacker space was better pizza handling. PizzaShovel does just that. It uses a conveyor belt action that is kinda magical. It sneaks its way under the pizza without it needing to slider over the surface. I had seen this years ago as an industrial handling device that can even pick up a blob of ketchup and place it down just the way it was. Pizza is not quite as challenging but raw dough is not trivial move around either.
      Boxes with a mission
      First project actually in 2024 was the AirPurifier I did on collaboration with MachineryEnchantress Naomi Wu. It's a simple box with a filter or two and a few PC fans:
      It is the first in a long list of boxes with a few features added to turn them into something else - even if they are still very boxy at heart.
      A very beautiful example is ojensen5115's CoinBankSafe. It's "just" a box with a hinged lid. But dials and a slit on top make it into a very nice piggy bank. The "lock" is simple but just fine for this purpose. There is a future project to upgrade to a proper combination wheel for someone.
      The BrickSorter by fidoriel turns boxes into a set of sieves to sort your favorite building blocks.
      DiceTower has been on my ToDo list for a long time. But there are so many options and possible features: a bowl to catch the dice, a lid so it can be used as a dice container, may be have the catching bowl be detachable to you can toss the dice back in with it, ...
      I never could bring myself to just do the simplest possible solution - just a box with a few angled walls within. Thanks to tljuniper for doing just this.
      ZBeam by jasondunsmore is meant as a cable channel with a mounting tab. It also offers a U channel option. It is basically the continuation of the LBeam by the very same means.
      Storage Solutions
      Storing things and especially small objects is the bread and butter of Boxes.py. There are quite a few new options in this area. But a good portion are variants of other generators.
      The GridfinityDrillBox is just the normal DrillBox but rehashed for the Gridfinity system. This is something one could probably been able to do before by carefully selecting the sizes and gluing on the the foot pad. With this generator this is much easier. These drills look a bit funny, though...
      The BinTray has been around for quite a while. But it is meant to be stationary.  pkochubey took the idea and combined it wit the Stackable Edge to get these beautiful and very useful StackableBins
      AlexCPU adjusted it to get it into the WallMounted group as WallStackableBin - allowing it to be hanged on a French cleats or slat wall.
      But he was not quite finished with the whole bin idea and created the WallHopper for even more storage space. I wonder if screws really is the best use of this when one could just as well put some candy in.
      WallRack is a bit of an odd one as it is not part of the regular WallMounted crowd that supports slat wall and French cleats etc. It instead sports just mounting holes for screws. Still a handy little storage solution that does not quite come with the complexity of the TypeTray configured for wall mounting.
      J-Waal's  CompartmentBox is a blend of the TypeTray and the CardBox offering a sliding lid over a grid of compartments.
      HobbyCase that JGrzybowski did for Hacktoberfest is a very nice storage solution for everything than needs many small pieces that need...
    • New Server!
      Florian Festi05/13/2024 at 20:25 0 comments
      As people surely have noticed the web instance was pretty slow at times. The issue was not really too much load but some weird latency or time out problem. As my hackerspace has setup a new server I asked if they would host Boxes.py. So now a new instance is available at https://boxes.hackerspace-bamberg.de. I added a redirect to the old location so you end up there no matter what. For now this is still in testing. Please report any issues you have here or on the GitHub project. If everything works out fine I will change all the links to the new instance.
      Update: Looks like everything is working fine. I switched over the URL in all places I could think of. So the web instance is now officially move to its new home. Please enjoy the much quicker response times!
    • Personal Backlog
      Florian Festi03/08/2023 at 23:13 1 comment
      Being able to put more time into the project have I looked into my local repository and it is full of half finished projects - most of them new "box" generators. I have been working on getting some of them in shape for inclusion. Additionally there where a few needs that popped up that also needed instant addressing. Funny enough a lot of these new generators come in pairs.
      So I did a roll holder for the kitchen after the old, 3D printed one broke:
      Well, it is mounted to the wall... so a "Wall" variant was needed:
      After finishing both I found another 20% finished holder in my working dir. It is more ambitious with 3 layers on each side that allow locking in the axle by rotating the middle layer. No idea why that didn't get finished. May be one day the two above get a fancy sibling...
      For another project I need to 3D print a small part (yes, I know, heresy) but the filament didn't come with it's own spool. So, I did a spool that can be separated into two parts using the BayonetBox as a basis:
      And as I was at it it was just too easy not the strip it down to a one piece spool (and then add some fancy reinforcements):
      One generator I started a long time ago was one for generating Tetris blocks. At the time this wasn't that easy and quite a bit of work. Nowadays this is much easier as we have the polygonWall method that gets a list of lengths and angles and handles the rest. There also is a companion method to create all the side walls from the same list. So the only tricky part was getting the lengths right as we do want the walls to be within the perimeter of the block structure. I am optimistic they fit, but I have not yet cut them out. So if you feel adventurous and "need some Tetris blocks in your life" please donate a few good pictures.
      Another "thing" that I started long ago and started over with more than once is my Seven Segments feature. The idea is to use a LED stripe on its side and wind it through the seven segments. So you can create a seven segment display without much soldering or special circuit boards and from semi small to quite big. The obvious use case is a seven segment clock. Both of them are still flagged "unstable". But I am not sure if I get to build one any time soon. So if one brave soul is looking an LED stripe fueled clock project let me know.
      So far my backlog is all but empty and I still have more ideas. I just started with a wire straightener holding two rows of v-groove ball bearings. I have a cryptic font that is mostly finished with each letter is just a few shapes that are only legible when surrounded by a border. I wanted to create a calendar with them, preferably perpetual or even some clever mechanical one. I saw a cube box at the Fablab of the University of Oulu that is cut directly between pieces without creating gaps. And I have a half working one for arbitrary sizes.  I have toyed a bit with flexures and thought about doing a laser cut microscope like the OpenFlexure Microscope although with very different kinematic. And I have a dozen more that are not much more than the first few lines of code and I am not confident enough to publicly admit here.
    • Old News and New News
      Florian Festi02/17/2023 at 10:43 0 comments
      It's been a while since the last proper log entry...
      The last few years were not that great for many things - including Boxes.py. But even with things going slow or not moving anywhere for months a lot of changes have piled up over this long time. Also it looks like this year is a lot better and things have actually already picked up speed in December of last year. Not only have I been able to do more but several old and new contributors have shown up and gave the project a very notable boost. To deal with the long backlog of new features and box generators while there is so much new stuff coming in I decide to mix in the old with the new.
      Wall Mounted Boxes and Tool Holders
      After a brief discussion here in the comments in early 2022 I factored and renamed the SlatWall group to WallMounted. While slat walls are fancy not many people have them. The whole group is only there because a few panels fell into the hands of our hacker space. Now the generators can have different styles of hooks and also work with DIN rails or French Cleats. It is relatively easy to add new ways of hooking the boxes and tool holders to different things. So it you have ideas open a ticket on GitHub - or start a discussion in the comments below.
      There are also few new generators in this group:
      • SlatWallPinRow allows you to hang stuff on the wall.
      • WallStairs allows you to design your own tool holders.
      and I recently added a few more sample images.
      On the search for the right box generator
      Caleb Crome is one of our new and very prolific contributors. One theme of his work is making finding the right box generator easier. He wrote a Gallery page that shows all sample images side by side for a quick overview.
      The second, complementary new feature is a search field on the menu page. It shows all matching box generators and matches the English name but also the translated name and short description. This is all done with some - not even too complicated - Java Script magic directly in the browser.
      A third feature is not merged yet. It will allow getting or adding QR codes with a link and settings of a generated box. That way it is easier to pass the settings around with a mobile phone or to figure out how to get the drawing from an already laser cut piece.
      These new features are not all Caleb has done so far. Prepare to hear more from him as soon as we get into new generators.
    • Server Health Improvements
      Florian Festi01/09/2023 at 15:35 0 comments
      The last few months complaints about poor performance and an increasing number of 502 errors have been piling up. The later were especially puzzling as it means there is a problem in the communication between the web server and uwsgi instance in the container. While there was some load on the machine everything looked fine at the first glance and there was nothing in the logs that hinted at a bug.
      At the same time there were similar complaints for the web2py application that runs on the same machine. Well, actually this thing is a VM that runs on a server of a friend of a friend that does a few other things and is only maintained to the bare necessity. When I put Boxes.py there the question I asked myself was not "How do I host the greatest box generator on the internet?" but "Now that I hacked argparse to produce web pages how can I show this to a few people?"
      Over the holidays I had time to look a bit deeper. Turns out the web2py app offers the data with different sorting and filtering and a horde of web crawlers eating it all up. Adding a robots.txt got rid of them and dropped the load from 0.7 to below 0.1. I may loosening this up a bit in the future but for now I just banned bots completely - including from Boxes.py.
      Looking at the logs from Boxes.py it was very apparent that there are even more connections coming in. Most of them of course are these nice pop-up images in the menu. While I still didn't have access the the main machine it dawned on me that the Boxes.py instance probably gets throttled down due to too many request. This would create timeouts and though the 502 errors. To fix that I moved all the pictures to the GH (documentation) pages and adjusted the links to point there. As this would be very annoying for people that run Boxes.py locally (me) this change affects the wsgi mode only. Yes, the boxesserver should grow a config file for things like that but I just couldn't be bothered.
      So performance has notably improved and I hope you all can now create your boxes without seeing 502 error messages. Looking into the access log it turns out there are quite  a lot of you. There are tens of thousands of request per day - even with the pictures moved elsewhere. This is kinda cool but also kinda scary...
    • It's all Fun and Games...
      Florian Festi10/23/2020 at 17:29 0 comments
      ...until someone makes an insert for Agricola - then it is even more fun ... and even more games:
      Kudos to Guillaume Collic who wrote this master piece. I especially like how he made use of already existing code and pieces and combines them with new edges types and new ideas. It re-uses the Divider Tray and regular boxes but combines them with new solutions like cutouts to make gripping the tiles easier. A very neat idea (but a bit difficult to see in the picture) are the sliding dividers in the trays for the wooden pieces. They are prevented from tumbling around by small triangular feet but are otherwise free to move left and right depending on how much space is needed in the compartments.
      The two box types holding the tiles clearly deserve to get a generator on their own. Guillaume already has ticket opened to make it easier to re-use complete generators by others. Splitting these boxes out might be a good exercise to create the infrastructure still missing.
      If you are on your way to your laser cutter you should probably stick to the default material thickness of 3mm or something close. While not stated in the generator description I have the suspicion that adding too much width with thicker material might end up with an insert that cannot be - well - inserted into the box.
      Inserts and organizers for board games is a very welcome new topic in the Boxes.py. I hope at some point we can make this a category in the UI and rescue this gem from the "Misc" section. I have the hope that Guillaume may contribute some more. But may his works also inspires others. The more pieces and features there already are the easier such task becomes.
    • New Boxes For Your Electronics Projects
      Florian Festi05/21/2020 at 12:32 0 comments
      Often just a generic box is just not enough, but you need something that can house the electronics of your project. The ElectronicsBox was the first variant with this in mind. But in the end it is just a box meant to be bolted down and screwed shut:
      QuitButton needed something else: A housing with a slanted front to mount a LCDisplay and a few buttons.
      As a first stop gap solution (other than just turning a pentagon box on it's side) I implemented Console using the relatively new polygonWall() code that turns a list of lengths and angles into a side wall. The actual win here is that there is a .polygonWalls() method that is rendering all the walls between the sides. The result is still a bit simple, but  at least has the right shape:
      But as with a lot of other boxes there is a severe lack of lockable doors or hatches. And while non rectangular finger joints are cool they are rather distracting around the front panel.
      So here is an improved Console2:
      There are a few variants. You can choose with or without removable back wall, with or without removable front panel and the front panel - as seen here -  clean and glued or attached with finger joints on the sides.
      The panel is held in place by spring loaded tabs:
      The two tabs per side and both springs being one single, laser cut piece.
      The back wall is hooked in at the bottom and has two flush latches at the top:
      The latches are made small enough that they cannot be opened or closed by hand but need a small tool like a screwdriver. This is on purpose to avoid people accidentally sticking their fingers into the electric parts inside. To prevent the latches from opening they have an integral leaf spring and a very small recess that locks them in place when closed. This way they can only be re-opened when pressed in a little bit against the spring.
    • Boxes.py on heise.de
      Florian Festi05/20/2020 at 19:48 2 comments
      Heise.de is the German speaking IT news site. The Heise publishing house also issues the Make magazine. So via the Make news feed this article in German (translated by Google) made it to get global feed at heise.de.
      There is nothing in the article regular readers of this project log don't already know about. But getting this level of exposure is quite nice and made my day.
      Herzlich Willkommen an alle Heise-Leser!
    • New Back End
      Florian Festi05/20/2020 at 08:23 0 comments
      So the new back end is finally merged into the master branch. If you update your own installation you need to install the affine Python module which is available both via pip but also in most distributions. Cairo is no longer needed. This should make installation on Windows much easier.
      The SVG produce by the new back end is also much better than the old one. Artifacts like repeated moves are filtered out and the outline of parts is much more continuous. The weird inverted arcs in inner corners are - for the most part - replaced with smooth Bezier loops. This should reduce acceleration in the corners and allow for faster cutting.
      I am still pondering whether it is worth adding a native DXF back end. While there is only very few commands needed by Boxes.py the format does not look like fun. I am also scared that it won't support the text the way we might need. For now the output still uses pstoedit for converting to DXF.
    View all 58 project logs
    Rich text editor
    stujen65 wrote 11/03/2022 at 06:35 point
    Thanks I checked it and now the error is fixed, it is working again. I appreciate your efforts :)
    josedj wrote 10/30/2022 at 12:40 point
    buenas , tengo un problema al crear cualquier caja al pasarlo al lightburn las piezas que deberían encajar no lo hacen ya que las medidas no son buenas , quería saber como es posible esto
    leroy wrote 10/28/2022 at 07:11 point
    I use your program to make stuff, I like it very much. I do have one comment on the dice box though. There is too much wasted space. I like the idea of it, however it is a lot of room for just one set of dice. I made cardboard boxes with your program to hold my dice . Most gamers have multiple sets. If I made a box for each of them (I have around 40 sets) I don't know where I would be able to store them. Thank you for listening and making the program.
    Bob the Builder wrote 10/21/2022 at 10:06 point
    Like gwvwadc , I too have been using the universal box for a good 12 months. Have had great success and should have commented ages ago. I am now getting the same error on any browser I use, Chrome, Edge and Brave. Everything else seems to work fine.
    gwvwadc wrote 10/18/2022 at 12:15 point
    I'm having problems designing universal box in Firefox browser. Every time I generate a project I receive this message
    Proxy Error
    The proxy server received an invalid
    response from an upstream server.
    The proxy server could not handle the request GET /boxes.py/UniversalBox.
    Reason: Error reading from remote server
    Apache/2.4.6 (CentOS) Server at www.festi.info Port 443
    I have tried different settings in parameters, cleared the cache in Firefox and restarted the browser, but still have the same message appear. This doesn't happen if I am using Safari (which I am NOT a fan of).
    All of the other design options appear to work correctly.
    I also should add that this problem has only recently appeared with Firefox.  I have used the universal design in the past with no problems at all.
    stujen65 wrote 10/22/2022 at 22:28 point
    I am getting the same issue, had it for about two to three weeks using chrome & edge. If I use safari on my Iphone I do not get the error.
    dt61373 wrote 09/30/2022 at 20:10 point
    Hey this Project is awesome!!, made my first sliding drawer box and now working on flex boxes.  Is there any way to get dove tail joints on the other boxes, or just the flex boxes? I love the aesthetic of dove tails.  Thanks and keep up the great work!!!
    Florian Festi wrote 10/01/2022 at 19:26 point
    The dovetails are only for joining flat panels and cannot create corners. This is a limitation of laser cutters - and Boxes.py - being 2D. As such their application is limited. The other generator that makes use of them is the JointPanel in Misc.
    afbigfish wrote 09/04/2022 at 16:30 point
    Ok, first I am loving this box generator.  Hoping someone can help with an issue I have.  Whenever I export the file as a DXF I get a double line with a whole bunch of extra funky lines in the corners.  When I export as an SVG its fine.  I would prefer to export directly as an DXF.  I have only had the laser for 2 days and made 2 projects but cant figure out this DXF issue. I tried all the different corner options for output and its all the same.
    Florian Festi wrote 09/07/2022 at 10:39 point
    Unfortunately there is not that much that can be done. The DXF is created from the PS (postscript) output by converting it with ps2edit. If anyone can suggest a better suited tool I am happy to switch to something more reliable. Tooling in this area is a bit sparse.
    Florian Festi wrote 09/21/2022 at 09:51 point
    May be converting the SVG with Inkscape is an option for you: inkscape --export-type=dxf --export-extension=org.ekips.output.dxf_outlines drawing.svg
    That's actually something I could add to the backend. Not sure if I want to run stuff through Inkscape on my server, though...
    Edit:
    Final conclusion in the Inscape Forum thread was
    inkscape --actions="select-all:all;selection-ungroup;selection-ungroup;selection-ungroup;object-to-path;select-all:all;selection-ungroup" --export-type=dxf --export-filename="C:\ExportFileLocation\NewExport.dxf" --export-extension=org.ekips.output.dxf_outlines "C:\OriginalFileLocation\OriginalSVG.svg"
    Not sure if this is really fitting as this wasn't about Boxes.py but it might give some clues on what to try.
    nir wrote 08/08/2022 at 20:09 point
    Hi :) Awesome project! Really!
    I think there's a bug wit the ShutterBox functions, it seems to be working only with 2/3mm thickness (I'm using the browser-based GUI). For example, using a thickness of 3.5mm leads to missing holes and more.
    I'll be manually fixing the file in light-burn, but just FYI :)
    Florian Festi wrote 08/10/2022 at 09:37 point
    I am not quite seeing that. But in general if edges get too small the fingers don't no longer fit and are omitted. So there is a minimum size where small details still fit. But you can make finger smaller in the Finger Joint Settings. Often it is already enough to lower the surroundingspaces setting to 1 or 0.5 or even 0.0 - the default for the ShutterBox is already lowered to 0.5, though. If the finger itself is too big you can lower the finger and space settings.
    nir wrote 08/10/2022 at 17:51 point
    Thanks for the help! It took me a while to figure it out, but I realized the surroundingspaces is too high like you said. It works well when I lower it (checking the 'debug' mode made things weirder by the way). I think the problem was that I had to cut things on my laser before I could figure out things are off. I'll dig into the code sometime and see if I could suggest a warning message when fingers or other parts are omitted. Awesome project, well done :)
    By the way, would it be okay if I post a YouTube video / instructables.com article with reference to the site? (you can see my work at nirlivne.com)
    Florian Festi wrote 08/12/2022 at 13:56 point
    The debug setting is more for developers who want to see if all the pieces are placed properly.
    Youtube videos and instructables articles are of course very welcome. I finally need to start a page where I collect such things.
    3dkev wrote 07/24/2022 at 16:42 point
    Hi, I can't get the plugin fully to work in Inkscape 1.2.1 on win 11.
    I'm using the boxes.py plugin from the Mightyscape plugin collection.
    I can change the values such as dimensions, material thickness etc.
    If I want to generate the SVG, or ask for a preview I get:
    There was no C:\Users\kevin\AppData\Local\Temp\box.svg output generated. Cannot continue. Command was:
    boxes angledbox --x 100 --y 100 --h 100 --outside true --bottom_edge F --n 5 --top angled hole --thickness 3 --tabs 0 --debug false --labels true --reference 100 --burn 0.1 --FingerJoint_angle 90 --FingerJoint_style rectangular --FingerJoint_surroundingspaces 2 --FingerJoint_edge_width 1 --FingerJoint_finger 2 --FingerJoint_play 0 --FingerJoint_space 2 --FingerJoint_width 1 --output C:\Users\kevin\AppData\Local\Temp\box.svg C:\Users\kevin\AppData\Local\Temp\box.svg
    I already let boxes.exe run as admin, and it has writing permissions.
    Florian Festi wrote 07/27/2022 at 22:20 point
    I don't really have any experience with Boxes.py on Windows - and even less with Inkspace on Windows. You are probably best off directly asking at the Mightyscape project who's author put a significant effort into packaging Boxes.py for Inkscape.
    ClaneSharke wrote 07/12/2022 at 14:29 point
    Could we have an option for slide on lid with finger joint rails on?  similar to the card box but with the bottom rail finger jointed instead of a full panel for the bottom rail.
    Florian Festi wrote 07/20/2022 at 11:27 point
    This is actually a really good idea. May take a few more days to get that done, though.
    Aaron wrote 06/27/2022 at 21:52 point
    Hi all, I have a slight issue with the Type Tray divider/box. If I set the burn value so the outside edges are nice and tight the slots that join the continuous walls become too tight, this becomes more of an issue the bigger the box, therefore the tight joints are on multiple sliding surfaces at once, which all have to be slid at once, I would like to be able to keep the fingers tight, but there is no real value in having the wall slots super tight, it would be great if these burn values could be set independantly of the finger joint values. Thanks for reading.
    Florian Festi wrote 06/28/2022 at 07:01 point
    Yeah, I have run into that myself but was able to more or less force things in place. Opened a ticket upstream: https://github.com/florianfesti/boxes/issues/410
    As noted there this requires more infrastructure than one might think from the outside. But that would also allow more features for the slots - like having them snap locked in place. This would be very useful for things like the TrayInsert which is currently a bit flimsy.
    Craftfoodandbeer wrote 06/22/2022 at 18:29 point
    Howdy, Your tool is amazing. I make lots of acrylic and wood boxes with it, Thank you for making it. How can I add the slide on lid from the card box to a Tray Layout? That would help me make the perfect box for some hobby projects I have in mind.
    Florian Festi wrote 06/26/2022 at 19:45 point
    You currently can't. Either you need to write a new generator or pick and choose the parts and hole patterns from both generators. As an alternative you could glue a TrayLayout into a CardBox - may be replacing the pieces at left and right.
    aidenapearce wrote 04/29/2022 at 17:19 point
    Hi Florian, fantastic project. I can see a lot of uses for this tool.
    One feature suggestion, or perhaps there's a setting I can't find, but it would be really nice to be able to make typetray or similar boxes with different thickness of material for the outer walls and inner dividers. For a complicated case, this could make a much smaller, and cheaper, box with sturdy sides.
    Florian Festi wrote 05/01/2022 at 10:30 point
    Yes, you are not the first one to make this suggestion. I guess at some point someone has to put in the work to make this happen.
    Chris Davis wrote 04/20/2022 at 15:08 point
    After creating a box using the web interface, when I export the image using Save as PDF, the resulting file is larger in scale, so the boxes are off by 5-10mm. Is this a common problem?
    Florian Festi wrote 04/27/2022 at 06:35 point
    See https://florianfesti.github.io/boxes/html/faq.html#why-is-my-box-a-bit-too-big
    If this doesn't explain what you are seeing please open a ticket on Git Hub with the link to the generated box: https://github.com/florianfesti/boxes/issues
    immztoivo wrote 04/10/2022 at 18:27 point
    Hey, boxes.py does not work. It just gave me an error:
    Gary Kean wrote 03/11/2022 at 23:16 point
    Hey Florian,
    I only recently installed boxes.py and am enjoying it very much, but I have run into a weird anomaly.
    1) Whenever I build a box using the "burn" option, I get a file that some of the corners have loops instead of crisp corners, some have small curves, and still others seem square and fine. I found that if I set the "burn" option to "0.0", these problems go away. It seems, however, that that feature is very useful to allow for kerf in my designs. Any thoughts?
    2) Is there any way to have the option of having different length fingers for box base (and top) perimeters and fingers for box sides? In other words, I'd like to have 5 width fingers on the floor of the box and 2 width fingers up the sides.
    3) Trays - Is there any way to have consistent fingers around the base rather than having the side divided and the fingers centered on the size of the individual sections?  It would be nice to have the creation of fingers ignore the sections created inside the tray. I make mostly non-symmetrical trays and the fingers get skewed based on the size of the final sections rather than being consistently placed around the base.
    Thanks
    Florian Festi wrote 03/19/2022 at 15:00 point
    1) https://florianfesti.github.io/boxes/html/faq.html#why-are-there-tiny-weird-loops-in-the-corners
    2) no, not with any of the current box generators. One way to achieve this might be frankenstein a box from two boxes with different settings by copying the finger holes or bottom edge over.
    3) no, this sort of thing might work for some edges but the walls inserted from above need to be split properly to avoid fingers hitting the perpendicular walls.
    Florian Festi wrote 04/20/2022 at 10:31 point
    Oh, I forgot to mention it here: I added a "inner_corners" option that allows you to choose the way those are rendered. Choosing "corner" will make those arcs disappear.
    Pedro Marques wrote 02/01/2022 at 13:12 point
    It would be great to have more DinRail sfuff like shelfs or other systems.
    Imagine to have stuff to use Din Rails like french cleats
    Florian Festi wrote 02/08/2022 at 14:10 point
    May be the Slatwall generators can be adapted to use the DinRail edges. This would give a good number of finished stuff.
    Pedro Marques wrote 02/09/2022 at 15:15 point
    yes that would be great...
    i think the way the "boxes" fix on dinrail can be more simple than the current dinrail template
    Chris Davis wrote 04/20/2022 at 15:11 point
    It would also be great to have a regular French cleat option too (adjust the height and depth of the cleat.)
    stevenhirst wrote 01/13/2022 at 15:27 point
    I would like to make the 'fingers' of the finger joints slightly longer than necessary. Say using 3mm material, if I could make the fingers 4mm and then sand them flat once the box is assembled to reduce the 'burned wood' effect.
    Is there a 'finger joint setting' for this?
    Florian Festi wrote 01/16/2022 at 14:48 point
    There is now (finally). See extra_length in Finger Joint Settings or https://github.com/florianfesti/boxes/issues/270
    samboa86 wrote 12/11/2021 at 21:28 point
    I'm sad with all these boxes there isn't one with a sliding off lid? That is the one that I needed. No body has designed one of these yet? lovely project overall
    Florian Festi wrote 12/21/2021 at 07:59 point
    Yeah, the lid situation is not that great yet. But there are a few options already: CardBox can be done with one compartment only. The TwoPiece box has a lid that slides off vertically. The UniversalBox supports a sliding lid with the matching top_edge selected. For something more fancy there is the ShutterBox.
    lechlew wrote 11/25/2021 at 08:37 point
    Hi, I have problem, because boxes generator is not working properly with output file ai or pdf. It generates svg file, dxf, but not pdf and ai. The problem is that sometimes it doesn't generate bottom of the box in ai file. Or only one wall. And sometimes it generates everything correctly. Please let me know what I do wrong.
