Semiconductors @ Home - Compendium V.005.pdf
The knowledge book to understand how to build all the DiY equipement needed to make semiconductors.
Adobe Portable Document Format -
48.45 MB -
10/23/2018 at 17:17
Preview
Semiconductors @ Home - Cookbook! V.007.pdf
Recipe book for the processes for making semiconductors @ home, using the tools developed in this project. This document is a research in progress, make sure to always check for the latest version.
9.44 MB -
10/22/2018 at 16:45
Preview
Tubular Semicon Kiln v6.f3d
3D model of the alumina bricks for the oven.
fusion -
387.25 kB -
10/19/2018 at 09:15
Download
Oven endcap ring.stl
Closing ring for the KF40 adapter.
Standard Tesselated Geometry -
457.21 kB -
10/19/2018 at 06:37
Download
Oven endcap adapter.stl
Endcap adapter from 45mm tube to KF40 for the fused quartz oven tube. Must be metal (can be 3D printed in aluminium, for example). Requires 12xM3*10mm screws AND 50OD*3,1mm O-ring.
2.97 MB -
10/19/2018 at 06:37
Download
Prensaestopas M12.stl
M12 to M6 gland.
1.81 MB -
10/15/2018 at 12:51
Download
Plate.stl
Plate holder for 2 M12 to M6 glands.
646.76 kB -
10/15/2018 at 12:51
Download
Tuerca 2 prensaestopas M12.stl
Nut for M12 to M6 gland.
240.32 kB -
10/15/2018 at 12:51
Download
Refrigerated Plate pocket.tap
Part 1 of 4. G-Code for the refrigerated plate. Intended as an example only.
This will drill out the pocket for the magnet trap.
tap -
47.75 kB -
10/03/2018 at 19:06
Download
Tweezers 3mm.tap
G-code of the Hydrogen Fluoride resistant HDPE tweezers. To be machined out of 3mm material. They accept square silicon pieces from 5x5mm up to 10x10mm
tap -
24.42 kB -
10/03/2018 at 19:06
Download
Mag bar holder V2.tap
Gcode for the PTFE guide for the axles. Accepts 6mm tube.
tap -
8.04 kB -
10/03/2018 at 19:06
Download
Mag driver 4mm.tap
Gcode for the press fit PTFE magnet carrier for a 4*0.5mm nested tube.
tap -
2.36 kB -
10/03/2018 at 19:06
Download
Mag driver 3mm.tap
Gcode for the press fit PTFE magnet carrier for a 3*0.5mm nested tube.
tap -
2.36 kB -
10/03/2018 at 19:06
Download
Mag driver 6mm.tap
Gcode for the press fit PTFE magnet carrier for a 6*1mm nested tube.
tap -
2.36 kB -
10/03/2018 at 19:06
Download
Refrigerated Plate o-rings.tap
Part 2 of 4. G-Code for the refrigerated plate. Intended as an example only.
This will machine the o-ring seats for the refrigeration plate.
tap -
1.30 kB -
10/03/2018 at 19:06
Download
refrigerated plate drill.tap
Part 3 of 4. G-Code for the refrigerated plate. Intended as an example only.
This will drill the holes for the acrylic seal piece.
tap -
1.26 kB -
10/03/2018 at 19:06
Download
Small drill support.stl
THIS IS AN EXAMPLE PIECE. Example pieces are only added for guidance, they should be modified to suit your particular alumina block, hole diameter, axle and bearing diameter. This will hold and position the small drill axle.
2.64 MB -
10/03/2018 at 18:58
Download
Bearing support Body.stl
THIS IS AN EXAMPLE PIECE. Example pieces are only added for guidance, they should be modified to suit your particular alumina block, hole diameter, axle and bearing diameter. This will hold the bearing for the big drill axle.
2.11 MB -
10/03/2018 at 18:58
Download
Bearing support top.stl
457.99 kB -
10/03/2018 at 18:58
Download
Small drill support TOP.stl
THIS IS AN EXAMPLE PIECE. Example pieces are only added for guidance, they should be modified to suit your particular alumina block, hole diameter, axle and bearing diameter. This will hold the bearing for the small drill axle.
194.91 kB -
10/03/2018 at 18:58
Download
Drill bearing spacer.stl
THIS IS AN EXAMPLE PIECE. Example pieces are only added for guidance, they should be modified to suit your particular alumina block, hole diameter, axle and bearing diameter. This piece will accept big ball bearings on the outside and a linear bearing on the inside. To guide the drill for the big hole.
146.08 kB -
10/03/2018 at 18:58
Download
Glass KF16 spacer.stl
This piece acts as a buffer for the flared borosilicate test tube, so the KF-16 clamp can't crush it directly.
580.55 kB -
10/03/2018 at 18:49
Download
Bottle holder semicon.stl
Fume hood bottle hoder, interconnectable. Requires a small suction cup (root diameter 5mm)
437.68 kB -
10/03/2018 at 18:49
Download
Manipulator controller V2 top-bottom piece.stl
Each piece attaches with 2x M3*8 screws to the 9mm linear rail, two must be printed, one mirror of the other, accepts 16mm glass tube.
183.48 kB -
10/03/2018 at 18:49
Download
TOP magnet carrier.stl
Requires 3x12mm M3 screws. Requires a modified 16mm borosilicate test tube, flared to accept KF16 fittings.
330.84 kB -
10/03/2018 at 12:34
Download
Manipulator Haptic controller Hand support V2.stl
Uses 2mm PTFE bowden tube + 0,8mm braided steel cable.
885.43 kB -
10/03/2018 at 12:34
Download
Manipulator Haptic controller Pulley V2.stl
Requires 6x 5*2mm neodimium magnets and 144x 3mm ball bearings, preferably ceramic, so they do not interactuate with the magnets inside. (alternatively a ball cage can be hand made out of 0,5mm material like teflon, requiring only 48 balls)
1.04 MB -
10/03/2018 at 12:34
Download
BOTTOM magnet carrier.stl
Requires a 9*100mm linear rail and 4x 6mm screws.
510.82 kB -
10/03/2018 at 12:34
Download
Manipulator Haptic controller Height carrier V2.stl
This piece acts as interface between the joystick and the linear bearing. Requires 15*100mm linear rail and 4x M3*10mm screws.
287.58 kB -
10/03/2018 at 12:34
Download
Manipulator Haptic controller finger piece V2.stl
Just a cable puller.
876.16 kB -
10/03/2018 at 12:34
Download
Manipulator Haptic controller Height support V2.stl
This piece gets attached to one end of a 15mm wide linear rail and acts as retainer for the bowden tube for height control.
154.87 kB -
10/03/2018 at 12:34
Download
Manipulator Haptic controller rail support V2.stl
This holds the 9mm interface rail, requires 4x M3*12mm screws.
230.36 kB -
10/03/2018 at 12:34
Download
