New vat mount.
09/01/2014 at 08:17 • 0 commentsYestarday i made a new vat mount. Wingscrews are used for a better vat leveling now. The vat mount is attached on four springs. I also use this construction for the new vat tilt mechanism.
New OpenExposer laser cut case
08/28/2014 at 08:20 • 0 commentsI am working on a new case for the OpenExposer.
Fixed some issues
07/15/2014 at 20:35 • 0 commentsI just solved the scattered light problem. Now i am working on a new protocol. I will switch to gcode. So it will be possible to use an existing host software . (e.g. pronterface).
Next week i will start to make the PCB Exposing (laminator like) attachment.
Open Exposer at the second German Maker Faire in Hannover
07/06/2014 at 23:42 • 0 commentsI am back from Hannover Maker Faire. Time to proceed with the project. Thank you to all visitors of my booth.
Copper plate as build platform
06/17/2014 at 20:15 • 0 commentsThe copper plate seems to work good. I am fighting with some scattered light. I don't know where it comes from. The first build of the Exposer Box doesn't have problems with scattered light. I changed the laser position last week, maybe i have to rework or calibrate the laser mount. I will find out tomorrow how to fix it, because there are many things to prepare for the Hannover Makerfaire.
Testing new build Stage Materials for 3D printing
06/13/2014 at 08:28 • 1 commentI have still problems to get the resin stick to the build stage. That is the reason why i made two new build stage versions. One which uses glas and another one which uses a pcb copper plate. Hopefully i will find a suitable material for the stage soon. Any suggestions?
See Open Exposer in action
06/11/2014 at 09:39 • 0 commentsVisit the "Make Light" booth at Hannover Makerfaire (5 and 6 of july). I will be there to show you the Open Exposer project in action.
Open Exposer and PCB exposing
06/10/2014 at 08:43 • 0 commentsAfter the Makerfaire in Hannover (Germany) i will start to build the PCB exposing extension. It should work like a laminator by pushing the copperplate through the Open Exposer unit. All parts will be 3D printable or laser cutable. The following rough sketch will give you an idea.
First test of the new z-axis construction
05/31/2014 at 09:53 • 1 commentHooray, the first test result of the new z-axis contruction with Spot-A-Materials Spot-GP resin looks good. Stage leveling is easier now. I can't wait to test MadeSolid's resin. There are some bugs in the host software. And i have to switch from my own binary protocol to a gcode compatible protocol.
Completed the new build stage
05/28/2014 at 09:21 • 0 commentsYesterday i printed the last 2 parts of the new build stage.
