11Step 11
Test the wireless charging. The orange LED must be on when both coils are near together.
12Step 12
Remove the mounting.
Now your wireless vibrator is ready. If you like you can build a charging station.
13Step 13
Optional: Build a charging station.
Print out both parts.
14Step 14
Cut a USB cable. Plug the cable through the hole of form B.
15Step 15
Now connect the USB wires with the sender module. Solder the red wire to the (+) pad on the wireless charging sender. Solder the black wire to the (-) pad.
16Step 16
Glue the sender board on the bottom of the red form. Put some glue on the cable to fix it. We used hot glue.
17Step 17
Now glue the black form and the sender coil together. We used simple “UHU”-like glue. If the distance between coil and form is too large the charging could be rather slow. So don’t use too much glue.
18Step 18
Now put together both parts. Again we used a simple glue.
19Step 19
Insert the USB connector to your PC or any other source. Now the vibrator should be charged which is indicated by an orange LED.
Ready! Have fun with your collection of wireless DIY Arduino-compatible vibrators.
