FPGATED v1.1
08/23/2016 at 20:41 • 0 commentsFinally joystick emulation is added to the FPGATED bundle. The main core ted.v is not changed, still on 1st release level , only c16.v and c16_keymatrix.v files have been modified. One joystick is emulated on the PS2 keyboard's numeric keypad similarly to fpga64. Keypad directions are the joystick directions and numeric 0 key is the fire. Use F11 to change between joy0 and joy1.
An external real joystick port 's appropriate pins can be added easily to kbus product terms. in c16.v.
Bug fix in v1.0.1 version
08/08/2016 at 21:57 • 0 commentsOriginal release has contained an incorrect c16_datalatch size in c16.v module. Xilinx ISE has corrected it automatically during synthesis however now it is fixed in v1.0.1
Also reset function is improved. Now reset signal of CPU becomes active while user keeps reset button pressed.
Mist-FPGA port
07/25/2016 at 18:41 • 0 commentsPorting FPGATED to Mist-FPGA has started!
Check it out at http://mist-fpga.net/viewtopic.php?f=17&t=198&p=1048#p1048
FPGATED v1.0 Released
07/21/2016 at 21:07 • 0 commentsFPGATED v1.0 released!
Finally I have verified and packed all source files to a bundled and released it.
Now FPGATED source files are downloadable!
It would be good if someone from NTSC world could test it and report the results to me as I have never had a chance to get close to an NTSC monitor for testing.
Project update
06/28/2016 at 20:31 • 0 commentsSorry for the delays in releasing the source codes and finalize the description.
I have not forgotten this project, the FPGA indeed works fine, I just could not find the time to clean up the code and release it in time. Latest by end of july I will release FPGATED 1.0 source codes!
Stay tuned!
