Real Life Use Of This Idea!
04/28/2016 at 12:05 • 0 comments![]()
Someone is already doing this. Sounds like a cool project to me...
Project Man-Cam
04/28/2016 at 11:11 • 0 commentsThe GoPro harness is on the way from LightInTheBox dot com for $7.99!!!
Decided that a utility cart would be better as it can hold the web-cam and the other equipment. Most museums and other venues MAY accept this. If you allow them to see the project is legit they probably will let you do it. About 5-6 museums worldwide are allowing telepresence robots now.
But here is someone else who is using a this method just like mine - notice time-stamp 6:12:https://youtu.be/ShQ3bY65k3U?t=6m10s
Here is my utility cart idea:
Coding
04/27/2016 at 21:31 • 0 commentsCoding javascript/asp private chat room using streaming text object on brinkster.
Ordering Parts
04/27/2016 at 21:29 • 0 commentsOrdering GoPro chest harness and building platform for web-cam.
Finding parts
04/27/2016 at 21:26 • 2 commentsRounding up all needed components.
First Log Entry
04/27/2016 at 21:10 • 1 commentI have most of the equipment. Just need the GoPro chest harness. Also need to code the private chat room.
chris jones
