Goals
The aim of this project is to explore diodes in unconventional uses, including, but not limited to the following crazy ideas. I need a place to document experiments as I go, without necessarily working towards a well-defined goal, and this is that place. If you're interested in contributing, send me a note; I'll add you to the project.
Diode-Diode Logic (spinoff from #The Diode Clock)
- Faster (I'd like to see 1 MHz clock frequencies before building a computer)
- SMD parts
- Using actual RF components (PIN /Schottky diodes)
- Better fan-out
- Diode memories (diode/capacitor DRAM)
Linear Amplifiers
- Headphone amplifier
- Diode op-amp
- Boutique audio (get that "diode sound")
Oscillators
- RC
- LC
- XTAL
Optoelectronics
- LEDs + photodiodes - you do the math
Homebrew Devices
- Copper oxide
- Selenium
- Zinc Oxide
- Borax rectifiers
- Crystal (galena) diodes
- Scavenged silicon
Power Supplies
- Diode-only (GUNN/IMPATT/tunnel)
- Mechanical (spark gap / high-speed alternator)
- Better supplies using transistors and ICs (the horror!)
And anything else relating to semiconductors that walk on two legs.
Tim
Yann Guidon / YGDES
Happy New Year Ted. Just finished finalized all my Light Logic gates last night. All are working great now. https://hackaday.io/project/161669-light-logic-hic-svnt-dracones
