The device is built around a ESP8266 (ESP-12E actually) and a SSD1306 I2C OLED display. It is battery powered (using a 18650 cell from a dead laptop battery). 2 buttons are used to navigate the interface and activate functions.
I also plan to use an "utility socket" to expand capabilities : https://hackaday.io/project/11869/log/38691-the-utility-socket-explained
Right now, working functions are :
- some nice navigation menus
- analog and digital clock
- gets real temperature using a DS1621 I2C sensor
- connects to known networks
- checks internet connectivity
- gets current time via NTP
- gets weather forecast on timed intervals (using a php script hosted on my home server)
- posts real temperature and voltage to my emoncms server on timed intervals
- shows my 3d printer status : on / off / disconnected, running state, hotend temperature
- gives details about the ESP chip : connectivity, ESSID, IP, free ram, battery voltage...
- On demand "WiFi smart config" : starts an AP and a webserver during 30s, allowing to add new WiFi credentials using a web interface.
- OTA firmware updates
Circuit board still needs some work : it is a prototype on a perfboard, and while it is working, I now want to move to a real PCB. Problem is : I can't find how to export a working gerber from Designspark software...
Arcadia Labs
The inside
Cover and buttons
Device start-up... Hello Jolly Wrencher ! :)
Test rig using the utility socket : a potentiometer to simulate analog input, and a IR receiver module to simulate digital input.
Analog monitor, with min, actual and maximum values, while playing with the potentiometer
Digital monitor while playing with the IR receiver and a TV remote (sorry for the blur, difficult to capture). Sampling speed could be changed with 10Hz increments. Next feature will be a new running mode, starting only on a pin change, sampling during a fixed time, and then showing on a scrollable / zoomable static graph.
mircemk
terryspitz
John Grant
Bolan Xu
Seems good. I want to test the same program with metal training knife project, you can see here https://combatica.co.uk/collections/metal-blunt-training-knives
