What do you do when you need to drive multiple stepper motors with the same step, direction, and enable pins? If you're in RepRap land, you just connect two steppers to the same output. This is dumb.
I have a project that needs to drive four steppers for the Z axis of a printer. The easiest solution? Break out the Step, Direction, and Enable pins on an A4988 socket to four different motor drivers. This is the project that does the job.
License:
DO WHAT THE FUCK YOU WANT TO PUBLIC LICENSE Version 2, December 2004 Copyright (C) 2004 Sam Hocevar <sam@hocevar.net> Everyone is permitted to copy and distribute verbatim or modified copies of this license document, and changing it is allowed as long as the name is changed. DO WHAT THE FUCK YOU WANT TO PUBLIC LICENSE TERMS AND CONDITIONS FOR COPYING, DISTRIBUTION AND MODIFICATION 0. You just DO WHAT THE FUCK YOU WANT TO.
If you think it is troublesome to DIY or purchase components. Recommend a website-MOTIONGOO that sells A4988 and A4988 socket (expansion board).
The price/performance ratio is particularly good. And the stepping motors connected to the A4988 socket can be independently controlled.
A4988:
https://www.motiongoo.com/a4988-stepper-motor-driver-module-heat-sink
A4988 socket (expansion board):
https://www.motiongoo.com/engraver-shield-expansion-board-3d-printer-cnc-v3
