Segunda Versao Super tecnologica
05/29/2016 at 01:13 • 0 comments//Autor Jose Pedro R. A. Ribeiro josepedrofederal@yahoo.com.br 28/05/2016 Processing 3.1.1
import processing.serial.*;
Serial myPort;
int time, i, currentServoAngle, k, m, ANGLE, DISTANCE;
float ANGLE_RAD;
float x, y;
float[] x_mem=new float[200];
float[] y_mem=new float[200];
float[] x_width =new float[200];
float[] y_width =new float[200];
int CHECK_ANG_INT;
int CHECK_SON_int;
int OBJECT_WIDTH = 4;
PFont Font1;
void setup() {
size(800, 400);
Font1 = createFont("Times New Roman Bold", 16);
println(Serial.list());
smooth();
myPort = new Serial(this, "COM8", 115200);
translate(400, 400);
void draw_background()
background(0, 30, 30);
fill(0, 102, 51);
textFont(Font1);
text("Arduino Radar processing 3.1.1", 10, 30);
fill(0, 51, 0);
arc(400, 400, 800, 800, PI, 2*PI, CHORD);
noFill();
stroke(0, 251, 32) ;
arc(400, 400, 700, 700, PI, 2*PI, CHORD);
noFill();
arc(400, 400, 600, 600, PI, 2*PI, CHORD);
noFill();
arc(400, 400, 500, 500, PI, 2*PI, CHORD);
noFill();
arc(400, 400, 400, 400, PI, 2*PI, CHORD);
noFill();
arc(400, 400, 300, 300, PI, 2*PI, CHORD);
noFill();
arc(400, 400, 200, 200, PI, 2*PI, CHORD);
noFill();
arc(400, 400, 100, 100, PI, 2*PI, CHORD);
line(400, 400, 400, 0);
line(400, 400, 25, 250);
line(400, 400, 775, 250);
line(400, 400, 115, 115);
line(400, 400, 685, 115);
line(400, 400, 235, 35);
line(400, 400, 565, 35);
void draw() {
draw_background();
String INPUT_ANGLE = myPort.readStringUntil('*');
String INPUT_DIST = myPort.readStringUntil('^');
if (INPUT_ANGLE != null) {
INPUT_ANGLE = INPUT_ANGLE.replaceFirst("\\*", "");
ANGLE=int(INPUT_ANGLE);
ANGLE_RAD=radians(ANGLE);
currentServoAngle=ANGLE;
if (INPUT_DIST != null) {
INPUT_DIST = INPUT_DIST.replaceFirst("\\^", "");
DISTANCE=int(INPUT_DIST);
DISTANCE=DISTANCE*5;
if (1 == 1)
if (DISTANCE>=300) {
// Large distance object need not be plotted
DISTANCE= 0;
println(DISTANCE);
println(currentServoAngle);
i=i+10;
x=DISTANCE*cos(ANGLE_RAD);
text(400+x, 10, 60);
y=DISTANCE*sin(ANGLE_RAD);
text(400-y, 10, 80);
x_mem[currentServoAngle]=400+x;
y_mem[currentServoAngle]=400-y;
if (DISTANCE < 300 )
x_width[currentServoAngle] = 400 + ((DISTANCE + OBJECT_WIDTH)*cos(ANGLE_RAD));
y_width[currentServoAngle] = 400 - ((DISTANCE + OBJECT_WIDTH)*sin(ANGLE_RAD));
} else {
x_width[currentServoAngle] = x_mem[currentServoAngle];
y_width[currentServoAngle] = y_mem[currentServoAngle];
// if (DISTANCE<400)
for (k=0; k<180; k++)
stroke(127, 255, 0);
fill(127, 255, 0);
ellipse(400, 400, 4, 4);
ellipse(x_mem[k], y_mem[k], 4, 4);
ellipse(x_width[k], y_width[k], 4, 4);
//line(x_width[k], y_width[k], x_mem[k], y_mem[k]);
if (i>800) {
i=0;
noFill();
stroke(255, 0, 51) ;
arc(400, 400, i, i, PI, 2*PI, CHORD);
arc(400, 400, i-1, i-1, PI, 2*PI, CHORD);
arc(400, 400, i-2, i-2, PI, 2*PI, CHORD);
arc(400, 400, i-3, i-3, PI, 2*PI, CHORD);
arc(400, 400, i-4, i-4, PI, 2*PI, CHORD);
//lembre se veja qual porta serial que esta no ide arduino defina placa e porta .no caso porta serial "COM8".Coloque a sua no programa linha 19
sensor ultrasônico HC-SRO4
05/28/2016 at 19:43 • 0 commentsO sensor ultrasônico HC-SR04 funciona como um detector de objetos e permite medir distancias mínimas de 2 centímetros podendo chegar a distancias máximas de até 4 metros com uma precisão de 3 milímetros. Estes sensores emitem um sinal ultrassônico (40 kHz) que ao atingir um objeto, retorna ao sensor. O sinal de retorno é captado, permitindo-se calcular a distância do objeto ao sensor, medindo o tempo de ida e volta do sinal emitido.
Usando a seguinte fórmula, é possível calcular a distância, sendo que v (velocidade do som) é ~350m/s.
d[m] = ( v[m/s] * t[s] ) / 2
Para a contagem do tempo, foi utilizado o Timer1, configurado de modo que incremente a cada 1us.
