Arduino Glasses a HMD for Multimeter
Building an HMD with no special parts, to make work easier and safer
Trying to build a cheap Arduino Data Glasses for everybody.
It's working, and now it can even help to avoid accidents. From the first idea to the working prototype, it took 4 Month
The challenge was, that It should be constructed out of common materials that can be found easily.
The project is more about how to build the optical system for this HMD
I have a few ideas and one of them is to connect it to a Multimeter over Bluetooth to get the Data right in front of my eyes.
One thing is clear, you can not just place a screen in front of your eyes, because it will not be possible for them to focus it.
In the logs you can see from the first tests to what I have now.
The whole project runs under Open Source License.
And please, if you use my design, do not forget to mention that it is based on my idea and add a link to my homepage www.alainsprojects.com.
Thank y
The optical design will be the most difficult part, but I think I found a solution for this.
Follow the project logs to see the updates. The costs of the prototype amounted to 70Euros.
Video of the working device
Link to the video and Link to the video in German
One of the Prototypes
Link to the video
part-a.stl
Standard Tesselated Geometry - 150.67 kB - 09/24/2016 at 21:03
Download
part-b.stl
Standard Tesselated Geometry - 160.63 kB - 09/24/2016 at 21:03
Download
part-c.stl
Standard Tesselated Geometry - 58.68 kB - 09/24/2016 at 21:03
Download
part-d.stl
Standard Tesselated Geometry - 62.58 kB - 09/24/2016 at 21:03
Download
part-e-45b.stl
Standard Tesselated Geometry - 36.61 kB - 09/24/2016 at 21:03
Download
  • 1 × arduino pro micro
  • 1 × Bluetooth V4.0 HM-11 BLE Module
  • 1 × 280mA Lipo Akku
  • 1 × 50 - 500mA LiPo Charger Circuit
  • 1 × 30mm acrylic plano convex lens with a FL of 100mm
View all 9 components
  • Feeling pissed off
    Alain Mauer02/26/2018 at 21:08 15 comments
    I'm really feeling pissed off, when I see people using my designs and try to sell them as their idea.
    This guy makes a nearly 100% copy of my Data Glass and only after I send him an email he added "inspired by Alain^s Projects". just inspired, really ???????
    I think that's not the way open source should work. If you use the work of someone else, the minimum is to mention this person and set his website link in the description.
    The only thing which calms me down, is that it is still my invention and other people will know it.
  • Lens Alternative
    Alain Mauer12/18/2016 at 11:27 2 comments
    Hi, the lens is still the problem, because it is not easy to find.
    I think, I found a good alternative. A small Fresnel lens. Easy to find, cheap and you can cut it with a pair of scissors.
    Hopefully I will find the time to test it.
    The focal length is about 110mm, with should be fine.
  • New Display 0.49 inch
    Alain Mauer10/18/2016 at 19:56 5 comments
    The new displays just arrived. Will build a smaller version.
    I think I will start a new project for this.
  • Things to do
    Alain Mauer10/10/2016 at 07:24 0 comments
    Thinks to do:
    • Finishing the Software, to auto connect to a Owon Multimeter
    • Adding a battery indicator in the display. The BLE module has this feature.
    • Building different reflectors with tint and mirror foils, to make the glasses work in a bright area,
    • Reducing the weight and redesigning the enclosure.
    • Testing with a smaller 0.49 inch display.
    • Creating a technical Data sheet
  • The end is near
    Alain Mauer09/19/2016 at 16:07 0 comments
    Finally, all fits together.
    Now a nice video of it, a full description and I'm done.
  • Modifying the charger circuit
    Alain Mauer09/17/2016 at 19:28 0 comments
    I needed to change the LiPo batteries. I use now a smaller, 280mA, instead of the 330mA. For this I had to change the resistor in the charger circuit. It's 3k smd part. I soldered a normal resistor with the value of 5.6k in place to reduce the charging current to 200mA.
  • A small reflector modification
    Alain Mauer09/16/2016 at 07:43 0 comments
    Until now, I heated the reflection screen and bent it to 45 degrees. To make the construction easier I printed a new holder. In the picture, you can see the difference
  • I looks like this will be the final design
    Alain Mauer09/15/2016 at 08:33 0 comments
    I finally start handling the 123Design software and my 3d Printer.
    I was totally focused on my cardboard design enclosure, but at the end, I had to redesign the glasses due 3d print problems. Now you can adjust the reflection screen, to get the best view.In the next few days I'll test the electronic with the new LiPo, but I'm still waiting for the lenses.
  • B.T. Data Glasses in his new enclosure
    Alain Mauer09/02/2016 at 16:08 2 comments
    I finally printed out the covers for the enclosure. The mirror and the lens are mounted with all the electronics. All fits in, and it works great. This one has a lens with a focal point of 100mm.
    All in. The controller, bluetooth, display, charger and the LiPo Batterie.
  • First 3d printed enclosure
    Alain Mauer08/31/2016 at 07:25 0 comments
    I just bought me a 3d Printer, and this is the first enclosure for my Dataglasses.
View all 37 project logs
  • 1
    Step 1
    How it works
  • 2
    Step 2
    The Lens
    The lens was a tricky thing. I had not really an Idea about optics. So I googled and googeld, and I learned a lot about real images, virtual images focal points, and magnification. The best working lens is an Acrylic Plano convex lens with a focal point of 100mm. If you place the screen at a distance of 73mm from the lens away, you will get a virtual image at a distance between 27-30cm. The magnification factor is x3
    That's perfect, because another important thing is, that your eyes can only start focusing things at +-25 cm
    I found this website to calculate the object distance.
    http://hyperphysics.phy-astr.gsu.edu/hbase/geoopt/image4.html
  • 3
    Step 3
    The electronic
    Here are all the parts for the data glasses
    I just used a smaller battery.
    To use the 280mA battery, I had to change the 3k resistor against a 5.6k resistor on the original board. The charging current is now reduced to +- 200mA.
View all 6 instructions
29310 wrote 06/03/2019 at 10:45 point
Hello, Alain! Since 2007, the bluetooth data transfer code has changed in the multimeter. Could you help to disassemble it under the sketch?
Singatumadreelcodigo wrote 05/30/2019 at 12:32 point
Same the code please
fatyarizkika09 wrote 05/28/2019 at 08:38 point
hello, can i  get the arduino code? im very excited to your project. my email fatyarizkika09@gmail.com
ZulaZabor wrote 05/10/2019 at 22:24 point
Alain,
The ghost picture is from the mirror. The picture is breaking on the surface of the glass and also on the silver in the back of the glass. Your have two images slightly moved from each other by the distance of the 45 º of the thickness of your mirror glass.
  You need a evaporated mirror, there is no second image, there is no glass in front of the mirror.
I hope this helps
kisaragishin wrote 05/10/2019 at 03:09 point
hello Alain. im very excited to do this project. Can i get the arduino code?
My email
kisaragishin98@gmail.com
Thanks
noreddine.malki95.nm wrote 04/08/2019 at 21:26 point
Bonjour, serait il possible d'avoir le code Arduino, ça serait superbe! Merci d'avance! Mon adresse mail est noreddine.malki95.nm@gmail.com
Vishal wrote 03/27/2019 at 06:34 point
Hello, I liked your project, you would be so kind to provide me with the arduino code, I would like to try to make some for me. Please, my email is Vishalmane929@gmail.com
Radicalprinting wrote 03/14/2019 at 01:39 point
im confused, I found a charger and battery, but I don't know what the break-out board is for. Can anyone help?
domheyland wrote 03/13/2019 at 20:01 point
Hello Alain. Would it be possible for you to share your Arduino code. I'd love to be able to try this out for myself.
Thanks Dom - domheyland@hotmail.co.uk
dzulsparta wrote 02/21/2019 at 09:46 point
hello, can i get the programming for my final project.
dzulsparta@gmail. com
Rodney wrote 02/09/2019 at 01:29 point
Plagiarism is the sincerest form of flattery. So please dont be pissed it only slows you down. Great idea/job on the glasses!
Andrei wrote 02/02/2019 at 21:19 point
have you tried to put screen just next to the reflective glass? Will that work? I mean will it be visible? I know you will have to modify screen library to display mirrored images. This should simplify and make your device smaller. As for me I really like it and will make it as a second step to my STM based navigation system once I make it fully work )
deshmukhninad.d wrote 01/21/2019 at 06:54 point
Hello Alain can you please help me with the arduino code
My email id is deshmukhninad.d@gmail.com
aminakmal2303 wrote 01/20/2019 at 08:28 point
aminakmal2303@gmail.com
william wrote 01/14/2019 at 11:17 point
love the project could you send the arduino code you used. Thanks keep making im new to all this and find it very amazing.
azmanhasan629 wrote 01/07/2019 at 11:26 point
sir, can i get a code for arduino?
azmanhasan629 wrote 01/07/2019 at 11:04 point
how to programming this arduino?
David wrote 01/04/2019 at 16:16 point
Hello Alain, it is a very good project, I printed and bought all the components. Can you send me the Arduino code? thank you
davidhl74@gmail.com
shiwacreative wrote 12/18/2018 at 23:15 point
wow great idea! can you send me the arduino code please :)
 shiwacreative@gmail.com
Domenico wrote 12/12/2018 at 11:38 point
Hello, i found your project very interesting, can you send me the arduino code? thank.
email: domi.comm@gmail.com
