Hackaday.io Hackaday.io
Sign up Log in
Pneumatic Exoskeleton
Vaguely based off of the exoskeleton from Elysium
james-hobsonJames Hobson
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
12.4k views
9 comments
162 followers
  • Description
  • Details
  • Files 0
  • Components 6
    • View all
  • Logs 11
    • View all
  • Instructions 0
  • Discussion 9
View Gallery
12.4k
9
162
70
Team (1)
  • james-hobsonJames Hobson
Join this project's team
  • Video Playlist
pneumatics exoskeleton elysium powered exokeleton pneumatic exoskeleton pneumatic
This project was created on 05/26/2014 and last updated 12 years ago.
Description
I've always wanted to make an exoskeleton ever since the first Iron Man movie. Unfortunately, an Iron Man suit isn't really realistic. The exoskeleton/loader from the Alien movies is -- but it'd cost way too much to build right now (someday...)
After the Elysium movie came out I had a new idea... A bare-bones, super basic, externally mounted augmented strength exoskeleton. Just like the one in the movie. Again, this wasn't going to be that cheap... until I came into possession of over a dozen pneumatic cylinders that were getting thrown out! I started designing it in CAD and...
Components
  • 8 × Speedaire 6W147 Pneumatic Cylinder 4" stroke, 1-1/2" bore, 250PSI max, 442LB at max pressure (http://www.grainger.com/product/SPEEDAIRE-Air-Cylinder-6W147)
  • 1 × 1" x 1" Perforated Steel Tubing Strong, rigid, light.
  • 1 × Festo 8-card valve bank Found at a surplus store for $70!
  • 1 × Nuts and Bolts
  • 1 × 3/4" Steel Box Tube (0.100 wall thickness)
View all 6 components
Project Logs
Collapse
  • The Big Test: Curling 170lb (80kg)
    James Hobson • 08/30/2014 at 12:57 • 0 comments
  • Preparing for the Big Test
    James Hobson • 08/30/2014 at 12:48 • 0 comments
    So unfortunately, I don't own weights to test this thing out... I'm thinking I'll try and make some concrete ones -- or as a fall back plan, just use cinder blocks.
    Okay so making concrete ones didn't work out so well -- cinder blocks will have to do.
    Last minute preparations before the big test...
  • Let's test it again!
    James Hobson • 08/30/2014 at 12:46 • 0 comments
    Alright so I've got the one arm mounted to the frame -- let's see how she works!
    Seems to work pretty good... Let's make the other arm and mount it all together!
  • Putting it all together
    James Hobson • 08/30/2014 at 12:43 • 0 comments
    Let's put it all together!
  • A Question of Joints
    James Hobson • 08/08/2014 at 10:51 • 0 comments
    One of the trickiest parts of this build will be keeping the exoskeleton flexible, so I've been looking at using Ball Joints (Spherical Rod Ends or Heim Joints). But can I combine two together to make a joint with more flexibility?
  • Building the Frame
    James Hobson • 08/08/2014 at 10:49 • 0 comments
    So to mount this thing on me I can't exactly copy the real Elysium design... not crazy about installing screws into my skeleton...
    I was trying to figure out a way to make a frame that can support a large weight so I looked at camping backpack frame designs... Perfect. But we're going to have to make one out of steel to make it a bit stronger.
  • Planning and Design
    James Hobson • 08/08/2014 at 10:46 • 0 comments
    Time for some planning before we get too far ahead of ourselves!
  • Successful Lift!
    James Hobson • 06/16/2014 at 12:37 • 0 comments
    It works! We're currently running it at 100PSI and even at that pressure it is capable of curling a battery that weighs 67lbs!
    These cylinders are rated for 250PSI, so hypothetically we could lift over 150lbs! Per arm!
  • The First Test!
    James Hobson • 06/16/2014 at 12:34 • 0 comments
    This is exciting -- let's test out the arm!
  • Testing out the Pneumatic Cylinders
    James Hobson • 06/16/2014 at 12:32 • 0 comments
    Now that I have a rough idea of what I'm doing, let's test out some of the components!
View all 11 project logs
Log In/Sign up to comment
Sign up with Github
OR
Dylan Bleier wrote 05/06/2015 at 00:19 • point
I think DARPA has done the same thing.  actually pretty cool.
LunaEros wrote 08/31/2014 at 19:22 • point
I like the Arc Reactor chest piece in the video.
Kinda says it all about your inspiration, goals, etc about the project.
Keep up the good work!
DISTEFANOMARIO wrote 08/31/2014 at 07:04 • point
Ciao James,
I appreciate a lot your efforts to build such a terrible machinery AT HOME (!) :-)
I only want to warn you, that since our own skeleton is not built to withstand too much overloads, some careful has to be taken into account for your knees and cartilage!
So there's ABSOLUTE NEED to add also legs of some sort, to this device, to give you a better stability under the load conditions.
Is way easier to replace a broken metal beam or a metal joint than the human counterpart!
Be careful!
Ciao & keep on the nice work!
Mario
BDM wrote 08/24/2014 at 16:06 • point
Lucky you being able to find pneumatic cylinders in the trash and great videos by the way, what software do you use?
James Hobson wrote 08/28/2014 at 01:32 • point
Thanks! I use Solidworks for all my CAD work
Alvin1248 wrote 06/02/2014 at 21:08 • point
If its money you need, seek out the usa military's funding. I've been in an experiment with wright Patterson air-force as a guest and was shown 2 things they were working on, and this technology of exoskeletons is it. They were describing carbon nano tubes to better the structure and weight so if lacking power it wont completely trap the human. but im sure your designs could help them. Most of them working on it was college students, and they had in my opinion no clue as what would be a good power source.
James Hobson wrote 06/16/2014 at 12:23 • point
Being a Canadian I don't think that'll work -- also I don't think pneumatics is really the way to go for military application... the problem is no power sources are that good yet anyway... For me it's more of a proof of concept, and a just for fun project.
dave.m.mcdonough wrote 05/28/2014 at 00:39 • point
What are your thoughts on controlling it?
James Hobson wrote 06/16/2014 at 12:22 • point
Down the road I'm hoping to use Thalmic Labs Myo gesture control device on each arm... but we'll see.
PS: Sorry I missed this, didn't get comment notifications!
Two jigs to assist in flexural testing and ensuring proper and repeatable alignment
Project Owner Contributor
Flex Test Alignment Jigs
patrickPatrick
Have you ever tried to make your very own beer? No? And why not? And why not to automate that?
Hacker's Beer
vojtech-vladykaVojtech Vladyka
The 2017 Hackaday Prize
Pocket Sized, 3d Printable, Coaxial Scout Drone
NAVI - "Hey, listen!"
glytchGlytch
Actively stabilized model rocket by means of a motor gimbal, originally designed for launching a rocket from a high-altitude weather balloon
Project Rockoon
julian-costasJulian Costas
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Pneumatic Exoskeleton", please tell us the reason.
Send message
Remove Member
