The git repo (in the links section) contains the LaTeX source and printable pdf files for perfboards and stripboards. Use them to lay out your prototypes before you screw it up due to skewed lines and such!
I keep drawing ugly lines on paper before I start/after I screwed up building some circuit on stripboard or perfboard. Here's my workaround.
http://www.linusakesson.net/hardware/chiptune.php
I wonder how hard it would be (or if anyone has already) to recreate those scripts to create the eps files. Seems like a really neat way to prototype that eliminates a lot of mistakes.
