Specifications: Number of flashlight components: 15 Color of LED’s light: white Number of LEDs: 3 Light Distance: 2-3 meters Size of flashlight : 26.25mm x 20mm x 5mm Current consumption : LEDs turn ON: 4-5mA LEDs turn OFF: 30-45uA Battery capacity: 140mAh Battery voltage: 3V Battery life : up to 6 months (if flashlight turns on 2 times for 60 sec in 24 hours) Required skills : knowledge of soldering SMD components
