Mugsy is an internet powered coffee making robot! #drinkcoffeeanddestroy
shroudMark5.stlThe shroud contains and mounts the filter to grinder assembly. . Build instructions to come. Print @ .2mm layer hight and 20% infill. No support.plain - 19.26 MB - 08/16/2016 at 17:15 |
beanHopperV3.stlThe hopper carries the whole beans into the grinder. Build instructions to come. Print @ .2mm layer hight and 20% infill. No support.plain - 10.22 MB - 08/16/2016 at 17:15 |
Are you in the Seattle area? Come hang and check out Mugsy in person at the Seattle Mini Maker Faire!
September 17-18, 2016
10:00am-5:00pm
EMP Museum (325 5th Avenue N at Seattle Center)
Currently cleaning the code base for the first public commit.
Github Repository: http://github.com/margyle/heyMugsy
A note on part substitutions:
The components list is the specific parts I'm using in my prototyping build. Lots of the parts can be swapped if that is your preference. As I write the build manual I'll try to note when a part or process can be handled differently.
Mugsy can run headless so a screen is not necessary. It defintely makes it cooler though....
Added initial Hardware components, structural components to be added.
Started initial file uploads for Mugsy's 3d printed parts.
Added test vids to description.
