Mugsy @ Seattle Make Faire
08/22/2016 at 19:02 • 0 commentsAre you in the Seattle area? Come hang and check out Mugsy in person at the Seattle Mini Maker Faire!
September 17-18, 2016
10:00am-5:00pm
EMP Museum (325 5th Avenue N at Seattle Center)
Code Repo
08/22/2016 at 17:02 • 0 commentsCurrently cleaning the code base for the first public commit.
Github Repository: http://github.com/margyle/heyMugsy
Part Substitutions
08/17/2016 at 16:36 • 0 commentsA note on part substitutions:
The components list is the specific parts I'm using in my prototyping build. Lots of the parts can be swapped if that is your preference. As I write the build manual I'll try to note when a part or process can be handled differently.
Mugsy can run headless so a screen is not necessary. It defintely makes it cooler though....
Added initial hardware components
08/16/2016 at 17:44 • 0 commentsAdded initial Hardware components, structural components to be added.
3d Printed Parts
08/16/2016 at 17:22 • 0 commentsStarted initial file uploads for Mugsy's 3d printed parts.
Page Update
07/11/2016 at 19:57 • 0 commentsAdded test vids to description.
