PROM Programmer Driver
Portable Network Graphics (PNG) -
29.27 kB -
07/31/2017 at 13:22
Preview
CPU_FrontPanelAndLEDChaserEmulation.ino
ino -
12.36 kB -
08/08/2016 at 08:26
Download
Print to scale image of the IO Board design
246.16 kB -
07/31/2016 at 00:33
Preview
Print to scale image of the Timing and Memory Board design
218.87 kB -
07/31/2016 at 00:33
Preview
Print to scale image of the PC Board design
216.33 kB -
07/31/2016 at 00:33
Preview
Print to scale image of the ALU ADDER Board design
220.40 kB -
07/31/2016 at 00:33
Preview
Print to scale image of the ALU NAND Board design
219.06 kB -
07/31/2016 at 00:33
Preview
Print to scale image of the Comparator Board design
205.59 kB -
07/31/2016 at 00:33
Preview
An animated GIF of Weird CPU running an LED Light Chaser Program.
Graphics Interchange Format -
1.62 MB -
07/30/2016 at 09:52
Preview
MonitorPROMHighNimbbleWriter.ino
PROM Programmer code for writing the high nimble of the Monitor program to PROM
ino -
6.36 kB -
07/29/2016 at 12:31
Download
MonitorPROMLowNimbbleWriter.ino
PROM Programmer code for writing the low nimble of the Monitor program to PROM.
ino -
6.34 kB -
07/29/2016 at 12:22
Download
A photo of the PROM Programmer
JPEG Image -
1.41 MB -
07/29/2016 at 12:21
Preview
The strip-board design or layout of the PROM Programmer
154.27 kB -
07/29/2016 at 12:21
Preview
Monitor.xlsm
This is the code for the monitor. Basically a very simple assembler macro that allows the use of labels, constants and aliases. To code by hand is a bit too hard!
application/vnd.ms-excel.sheet.macroEnabled.12 -
38.70 kB -
08/04/2016 at 03:45
Download
ProgramLedChaser.xlsm
My favourite, a simple LED light chaser. As the CPU does not have a SHR instruction it is done in software. If I build another CPU it will definately include this instruction.
37.48 kB -
08/04/2016 at 03:45
Download
Program8BitCounter.xlsm
A simple 8 bit counter.
36.28 kB -
08/04/2016 at 03:45
Download
1_CPU_IOBoard.diy
CPU: IO Board using DIYLC.
diy -
481.78 kB -
07/28/2016 at 10:24
Download
2_CPU_Timing&MemoryBoard.diy
CPU: Timing and Memory Board using DIYLC.
diy -
373.76 kB -
07/28/2016 at 10:24
Download
3_CPU_ProgramCounterBoard.diy
CPU: Program Counter Board using DIYLC.
diy -
448.10 kB -
07/28/2016 at 10:24
Download
4_CPU_ALU_ADDER.diy
CPU: ALU Adder Board using DIYLC.
diy -
402.12 kB -
07/28/2016 at 10:24
Download
5_CPU_ALU_NAND.diy
CPU: ALU NAND Board using DIYLC.
diy -
378.10 kB -
07/28/2016 at 10:24
Download
6_CPU_ALU_Comparator.diy
CPU: ALU Comparator Board using DIYLC. Not implemented!
diy -
336.73 kB -
07/28/2016 at 10:24
Download
16130_CPU.TSC
If you use Tina simulation software then this may be useful to you (same as 16130_CPU.jpg).
tsc -
223.73 kB -
07/28/2016 at 01:14
Download
Here is an image of the CPU design.
JPEG Image -
965.49 kB -
07/28/2016 at 01:16
Preview
