Hackaday.io Hackaday.io
Sign up Log in
YASS (Yet Another Smart Switch)
An ESP8266 descentralized smart switch mesh.
ariel-ivn-ruiz-mateosAriel Iván Ruiz Mateos
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
4.5k views
6 comments
73 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 4
    • View all
  • Instructions 0
  • Discussion 6
View Gallery
4.5k
6
73
31
Team (1)
  • ariel-ivn-ruiz-mateosAriel Iván Ruiz Mateos
Join this project's team
MISC
ongoing project
iot ESP8266 mesh smart switch
This project is submitted for
  • ESP8266 Micropython Contest
This project was created on 08/12/2016 and last updated 9 years ago.
Description
We are making an ESP8266 based smart switch. This could be descentralized, so you can send message between the smart switches to communicate with a far connected device with our simple mesh developed software.
Our smart swich could have four devices connected at the same time to be remotely controlled by a mobile app.
All without an internet connection!
(Upload image is illustrative)
Project Logs
Collapse
  • Finally we have a prototype pcb :)
    Ariel Iván Ruiz Mateos • 10/28/2016 at 02:07 • 1 comment
    Now we have a fully working wifi switch...
    We will upload a video soon!
    Stay tuned!
  • Now our esp8266 is alive!
    Ariel Iván Ruiz Mateos • 10/28/2016 at 02:04 • 0 comments
    Yes! our hacking session was successful!
    Now we will to connect everything!
    Next, we will create our pcb prototype. :)
  • Looking to create life into our esp8266 hacking a 5v power supply!
    Ariel Iván Ruiz Mateos • 10/28/2016 at 02:01 • 0 comments
    Hacking a 5V power supply to give us 3.3v! to give food to our esp8266 :)
  • And finally we are online!
    Ariel Iván Ruiz Mateos • 08/26/2016 at 13:37 • 0 comments
    We were a bit ran out of time but now we are active designing and developing our prototype!
    So, we are developing and testing our sketch into our esp8266-01, testing with leds, and it's working!
    In a few days we will working on turning on / off real devices!
    Please stay tuned.
    Thanks for your time!
View all 4 project logs
Log In/Sign up to comment
Sign up with Github
OR
Constantin wrote 10/31/2016 at 08:29 • point
How about adding a ACS712TELC module to measure current? :)
ESP wrote 10/29/2016 at 22:18 • point
Very interesting!!!
Why you only can controle four devices?
Do you use the ESP-NOW mode?
Erratic Bits wrote 08/24/2016 at 17:16 • point
I have been interested in how to make a smart switch myself.  Looks like a great project! I wasn't sure what the best method of converting AC to DC in a compact space might be.  I had found these converters (http://www.digikey.com/en/product-highlight/c/cui/encapsulated-ac-dc?&WT.srch=1&gclid=CKWSkvSM1c4CFQupaQodgmgM-g), but wasn't sure if this was the best way to go - not to mention these can be pricey.
ch.dugasduvillard wrote 08/26/2016 at 14:14 • point
Hi,
I had the same idea but with those converters: http://www.newark.com/webapp/wcs/stores/servlet/Search?pageSize=25&st=Vigortronix&catalogId=15003&categoryId=800000087512&langId=-1&storeId=10194
But I'm also thinking that they are a little expensive.
Ariel Iván Ruiz Mateos wrote 08/12/2016 at 23:23 • point
Hi Christophe! thanks for your comment, this image is illustrative, we will create our design.
ch.dugasduvillard wrote 08/12/2016 at 09:50 • point
Hi,
Your products looks very good!
What power supply do you use ?
Christophe.
The BSPD is a component required for Formula Student competitions.
Project Owner Contributor
Formula Student Brake System Plausibility Device
putmotorsportPUTMotorsport
Ongoing design for an internet enabled pillbox to dispense medicine on a schedule.
SmartDose
brian-kwonBrian Kwon
2021 Hackaday Prize
Low power e-paper dashboard using ESP32
paperd.ink
rohit-gujarathiRohit Gujarathi
Create a home automation gateway, you can access from anywhere, using a Raspberry PI, Sonoff switches with Tasmota and FlashLex.
Internet Accessible Home Automation with Sonoff
clay-grahamClay Graham
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "YASS (Yet Another Smart Switch)", please tell us the reason.
Send message
Remove Member
