Functioning & Calculations
09/24/2016 at 18:12 • 0 comments![]()
TORQUE CALCULATION
MOTOR 3
MOTOR 2
MOTOR 1
Product Specifications
Height Adjustment
2 Feet ( Automatic )
Distance from stand
1.5 Feet
Battery Life
4 Hours
AC supply
220-230 V
Current Required
2-3 A
Food Volume
1.5 Liters
Food Types
Semi-solid
Sensor to prevent spoon hitting the teeth
Yes
Total Weight
2-3 Kg
Device Height
10 Inches
Device Diameter
14 Inches
Legend No.
Legend Description
1
Base
2
Upper rim of the base
3
Rotation Adjustment
4
Channels for distance adjustment
5
Motor for rotating the bowl
6
Bowl
7
Motor for guiding the spoon to scoop the food
8
Motor forspoon movement
9
Spoon
10
Haptic Feedback Button
11
Battery Pack
12
Cross scissor lift
13
Electronic housing
14
Camera
15
Level 1
16
Level 2
17
Level 3
18
Assistive feeder device
19
220-230 V plug
Ayushman Talwar
