For MacroFab Design Contest: Useless Machine
07/31/2019 at 22:13 • 0 commentsWith this project you can not make nothing useful.
New magneboot board with touch controll
12/19/2018 at 14:26 • 4 commentsOf course again LEGO compatible holes for easy make maze ;)
Ordered magnetBots​
05/18/2018 at 08:23 • 0 commentsI designed about 8 types of bots with precise magnet aliment.
Also with 0,8mm and 1,6mm thicknes and with 4layers coil.
D21 touch controller / driver
05/15/2018 at 12:38 • 0 commentsSAMD21 (arduino zero) controller / driver board
6 power outputs
5 touch buttons
Hi res PCB in factory - ONE WEEK TO NEXT TEST
05/10/2018 at 22:44 • 1 commentNew board finished, I am decided for separated controller board. I think new board is much better designed only one moving track is divided with vias and also I doubled vias for highher current.
Board is only 0.6mm thick to improve force of bottom moving track.
ONE WEEK TO TEST
NEW bigger and Hi-res platform
05/10/2018 at 13:33 • 3 commentsNew moving platform with 1mm precision.
Microbot - Button control - WORKING !!!
05/04/2018 at 22:07 • 0 commentsJust I waiting for smaller magnets, but it is GREAT !!!!!
SRI INTERNATIONAL patent
05/04/2018 at 13:10 • 3 commentsFinally I found SRI INTERNATIONAL patent with description https://patents.google.com/patent/US8593016B2/en
My solution is little different, I am using another pattern for movements also my design is 3 phases uni-polar against they 4 phases bi-polar design. They design is very energy effective because they have levitating manipulators over
pyrolytic graphite.I searching samples of pyrolytic graphite.sheets, but without success now.
First test
04/30/2018 at 20:03 • 0 commentsI think there is high probability to sucess
Waiting for mosfets and 2mm magnets ...
bobricius
