VizLens::Wearable Cameras
09/29/2016 at 04:45 • 0 comments56.7% of the images took by the blind participants for crowd evaluation failed the quality qualifications, which suggests there is a strong need to assist blind people in taking photos. In our user evaluation, several participants also expressed their frustration with aiming and especially keeping good framing of the camera. Wearable cameras such as the Google Glass have the advantage of leaving the user's hand free, easier to keep image framing stable, and naturally indicating the field of interest. We have ported the VizLens mobile app to Google Glass platform, and pilot tested with several participants. Our initial results show that participants were generally able to take better framed photos with the head-mounted camera, suggesting that wearable cameras may address some of the aiming challenges.
VizLens::LCD Display Reader
09/29/2016 at 04:45 • 0 commentsVizLens v2 also supports access to LCD displays via OCR. We first configured our crowd labeling interface and asked crowd workers to crop and identify dynamic and static regions separately. This both improves computational efficiency and reduces the possibility of interference from background noises, making it faster and more accurate for later processing and recognition. After acquiring the cropped LCD panel from the input image, we applied several image processing techniques, including first image sharpening using unsharp masking for enhanced image quality and intensity-based thresholding to filter out the bright text. We then performed morphological filtering to join the separate segments of 7-segment displays (which are commonly used in physical interfaces) to form contiguous characters, which is necessary since OCR assumes individual segments correspond to individual characters. For the dilation's kernel, we used height > 2 x width to prevent adjacent characters from merging while forming single characters. Next, we applied small blob elimination to filter out noise, and selective color invertion to create black text on a white background, which OCR performs better on. Then, we performed OCR on the output image using the Tesseract Open Source OCR Engine. When OCR fails to get an output, our system dynamically adjusts the threshold for intensity thresholding for several iterations.
VizLens::State Detection
09/29/2016 at 04:43 • 0 commentsMany interfaces include dynamic components that cannot be handled by the original version of VizLens, such as an LCD screen on a microwave, or the dynamic interface on self-service checkout counter. As an initial attempt to solve this problem, we implemented a state detection algorithm to detect system state based on previously labeled screens. For the example of a dynamic coffeemaker, sighted volunteers first go through each screen of the interface and take photos. Crowd workers will label each interface separately. Then when the blind user accesses the interface, instead of only performing object localization for one reference image, our system will first need to find the matching reference image given the current input state. This is achieved by computing SURF keypoints and descriptors for each interface state reference image, performing matches and finding homographies between the video image with all reference images, and selecting the one with the most inliers as the current state. After that, the system can start providing feedback and guidance for visual elements for that specific screen. As a demo in our video, we show VizLens helping a user navigate the six screens of a coffeemaker with a dynamic screen.
VizLens V2
09/29/2016 at 04:43 • 0 commentsBased on participant feedback in our user evaluation, we developed VizLens v2. Specifically, we focus on providing better feedback and learning of the interfaces.
For VizLens to work properly it is important to inform and help the users aim the camera centrally at the interface. Without this feature, we found the users could `get lost' - they were unaware that the interface was out of view and still kept trying to use the system. Our improved design helps users better aim the camera in these situations: once the interface is found, VizLens automatically detects whether the center of the interface is inside the camera frame; and if not, it provides feedback such as ``Move phone to up right" to help the user adjust the camera angle.
To help users familiarize themselves with an interface, we implemented a simulated version with visual elements laid out on the touchscreen for the user to explore and make selection. The normalized dimensions of the interface image as well as each element's dimensions, location and label make it possible to simulate buttons on the screen that react to users' touch, thus helping them get a spatial sense of where these elements are located.
We also made minor function and accessibility improvements such as vibrating the phone when the finger reaches the target in guidance mode, making the earcons more distinctive, supporting standard gestures for back, and using the volume buttons for taking photos when adding a new interface.
System Implementation
09/29/2016 at 04:41 • 0 commentsVizLens consists of three components: (i) mobile application, (ii) web server, and (iii) computer vision server.
Mobile App
The iOS VizLens app allows users to add new interfaces (take a picture of the interface and name it), select a previously added interface to get interactive feedback, and select an element on a previously added interface to be guided to its location. The VizLens app was designed to work well with the VoiceOver screen reader on iOS.
Web Server
The PHP and Python web server handles image uploads, assigns tasks to Amazon Mechanical Turk workers for segmenting and labeling, hosts the worker interface, manages results in a database and responds to requests from the mobile app. The worker interfaces are implemented using HTML, CSS, and Javascript.
Computer Vision Server
The computer vision pipeline is implemented using C++ and the OpenCV Library. The computer vision server connects to the database to fetch the latest image, process it, and write results back to the database. Running real-time computer vision is computationally expensive. To reduce delay, VizLens uses OpenCV with CUDA running on GPU for object localization. Both the computer vision server and the web server are hosted on an Amazon Web Services EC2 g2.2xlarge instance, with a high-performance NVIDIA GRID K520 GPU, including 1,536 CUDA cores and 4GB of video memory.
Overall Performance
Making VizLens interactive requires processing images at interactive speed. In the initial setup, VizLens image processing was run on a laptop with 3GHz i7 CPU, which could process 1280x720 resolution video at only 0.5 fps. Receiving feedback only once every 2 seconds was too slow, thus we moved processing to a remote AWS EC2 GPU instance, which achieves 10 fps for image processing. Even with network latency (on wifi) and the phone's image acquisition and uploading speed, VizLens still runs at approximately 8fps with 200ms latency.
Formative Study
09/29/2016 at 04:38 • 0 commentsWe conducted several formative studies to better understand how blind people currently access and accommodate inaccessible interfaces. We first went to the home of a blind person, and observed how she cooked a meal and used home appliances. We also conducted semi-structured interviews with six blind people (aged 34-73) about their appliances use and strategies for using inaccessible appliances. Using a Wizard-of-Oz approach, we asked participants to hold a phone with one hand and move their finger around a microwave control panel. We observed via video chat and read aloud what button was underneath their finger.
We extracted the following key insights, which we used in the design of VizLens:
- Participants felt that interfaces were becoming even less accessible, especially as touchpads replace physical buttons. However, participants did not generally have problems locating the control area of the appliances, but have problems with finding the specific buttons contained within it.
- Participants often resorted to asking for help, such as a friend or stranger: frequently seeking help created a perceived social burden. Furthermore, participants worried that someone may not be available when they are most needed. Thus, it is important to find alternate solutions that can increase the independence of the visually impaired people in their daily lives.
- Labeling interfaces with Braille seems a straightforward solution but means only environments that have been augmented are accessible. Furthermore, fewer than 10 percent blind people in the United States read Braille.
- Participants found it difficult to aim the phone's camera at the control panel correctly. In an actual system, such difficulty might result in loss of tracking, thus interrupting the tasks and potentially causing confusion and frustration.
- Providing feedback with the right details, at the right time and frequency is crucial. For example, participants found it confusing when there was no feedback when their finger was outside of the control panel, or not pointing at a particular button. However, inserting feedback in these situations brings up several design challenges, e.g., the granularity and frequency of feedback.
