Hackaday.io Hackaday.io
Sign up Log in
Toenail Springs
Ingrown toenails are no fun
oneohmoneohm
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 5
    • View all
  • Instructions 0
  • Discussion 0
  • The 2016 Hackaday Prize
View Gallery
436
0
0
0
Team (1)
  • oneohmoneohm
Join this project's team
ongoing project
2016HackadayPrize
This project is submitted for
  • Assistive Technologies
This project was created on 10/02/2016 and last updated 10 years ago.
Description
How about an assistive technical fix for the common problem of ingrown toenails.
Toenail Springs -
-Small spring steel strips of differing strength
-Unobtrusive, flat profile
-Etched hole pattern ensures good adhesion
-Flexible superglue with disappearing dye for easy application
-Superglue accelerator pads pre-attached to the spring clips
-Removable with acetone nail polish remover
The idea is to relieve tension on the nail and gently reshape to a flatter profile.
Project Logs
Collapse
  • Preparing bond accelerator pads
    oneohm • 10/02/2016 at 22:44 • 0 comments
    The idea here is to pre-treat some small fabric/microfiber pads with something that will trigger the glue to cure instantly. I tried some Zip-Kicker, but the results were underwhelming - perhaps the active ingredient evaporated? There are other - even reasonably non-toxic substances that will rapidly cure cyanoacrylates. Baking soda seems to be the best option. Next time I will try to work some baking soda into the pads.
  • Joined spring assembly
    oneohm • 10/02/2016 at 22:37 • 0 comments
    A special flexible superglue (octyl/butyl cyanoacrylate blend) allows for a slightly flexible bond preventing the spring from breaking apart as the nail naturally flexes.
    https://www.amazon.com/Abbott-Laboratories-GLUture-Topical-Adhesive/dp/B00IJVQVO6
  • Trimmed and Ready to Join
    oneohm • 10/02/2016 at 22:31 • 0 comments
    Rounded corners might be nice - perhaps in the next revision...
  • Rough cut spring strips
    oneohm • 10/02/2016 at 22:29 • 0 comments
    Here are the rough cut spring segments - with similar width.
  • Preparing the springs
    oneohm • 10/02/2016 at 22:24 • 0 comments
    Starting with a sheet of etched screen mesh from E-Fab http://www.efabsales.com/screen-mesh/ I cut some small strips of different widths that included the border. I then trimmed these and glued them together with the border overlapping. The mesh acting as small attachment points on either end.
View all 5 project logs
Log In/Sign up to comment
Sign up with Github
OR
yay, grafitty
Project Owner Contributor
multi stencil experiment
rawerawe
An upper body model for making wearable technology items, articulated with skeletal approximations
Articulated torso with arms
kenji-larsenKenji Larsen
A quest 40 years in the making
How to win at epoxy
lion-mclionheadlion mclionhead
No more stuff rolling around the trunk with this custom insert.
Tesla Model S trunk insert with net
daviddavid
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Toenail Springs", please tell us the reason.
Send message
Remove Member
