Over the course of the project, development in China hasn't stopped. It's currently possible to order 4-in-1 modules with the MAX7219 on AliExpress for only €3.78.
If you only want a single piece, you could saw the module to pieces, or buy a single module for €1.09 from AliExpress.
If these modules had been available when I needed them, I probably wouldn't have taken the effort to design my own modules.
Update 2025-09-02 : If I had to design it again, I'd probably leave off the row controller. When creating a matrix of these LED-modules, it's not necessary to have a row decoder on each and every module in the matrix.
It's probably cheaper to create a PCB in the panel size you actually need instead of tying together multiple of these smaller modules.
Christoph Tack
hesam.moshiri
Arnov Sharma
Ai-Thinker
