The three PCBs:
- Original Viscount beats circuitry
- Stereo tube amp
- Power supply (AC 15V supplying direct to the amp, then rectifying to ~18V DC, supplying the +12V/-15V the Viscount board needs)
![](https://cdn.hackaday.io/images/5297831527430881697.jpg)
Building the case:
![](https://cdn.hackaday.io/images/9022631527430958481.jpg)
![](https://cdn.hackaday.io/images/9450111527430962232.jpg)
(kind of looks like a toilet seat here)
Then a ton of angle grinding. Every step of the case build made me appreciate why most boxes for things are, well, boxes: working with wood that curves in three dimensions is super annoying! You can't clamp it anywhere.
![](https://cdn.hackaday.io/images/9282031527431112627.jpg)
That said, it came out ok after all that:
![](https://cdn.hackaday.io/images/9725341527431142242.jpg)
Cutting the face:
![](https://cdn.hackaday.io/images/9316461527431203829.jpg)
Finally ready to put it all together…
![](https://cdn.hackaday.io/images/787321527431177306.jpg)
And there it is: a triumph of impracticality… perfect for Hackaday :)
![](https://cdn.hackaday.io/images/3368911527431251112.jpg)
Very cool! I'd love to hear how it sounds!
