ROV electronics and wiring - all together now
09/15/2018 at 02:05 • 0 commentsThe above photo shows all the ROV internal assembled inside the frame (the photo below shows the same assembly from the back)
The brains of the robot (center of both photos) consists of a stack of three boards:
- Raspberry Pi Zero W
- 8BitModule
- Ethernet + USB expansion board (https://www.tindie.com/products/marcel/raspberry-pi-zero-ethernet-rj45-and-usb-hub-shield/)
The two brushless thrusters (Turnigy Multistar 1704-1900Kv 12 Pole Multirotor Outrunners) are controlled by Afro 10A Escs (which came from HobbyKing but aren't sold anymore - the 20A version would work just as well) stuffed down the right hand side of the board (back photo) and a HiTec HS5645MG servo on the left handles the pitch control. A standard Raspberry Pi Camera is mounted on the front.
The wiring harness runs out the back of the ROV frame, but loops up and down into the main electronics space so allow the frame to pitch around the central "ball" with snagging anything.
Power harness and Tether
07/16/2018 at 01:38 • 0 commentsThe picture above show the power harness for inside the ROV. The tether comes into the harness on the left, and various plugs and connectors are shown on the right. These connect to the ESCs power inputs, the 8BitRobot module, and the internal battery.
The tether configuration is shown below:
Different configuration of the tether allows different operations to be performed on the ROV:
- External power on BLACK + YELLOW: Charge the internal battery.
- External power on BLACK + RED: Power the ROV from the external power source.
- Bridge RED + YELLOW: Power the ROV from the internal battery.
These different options should (hopefully) remove the need to open the ROV except for maintenance.
Bucket Test
07/15/2018 at 00:53 • 0 commentsWith the frame complete and all the wires potted, it's finally time for a water test. Fortunately I don't have to risk any electronics for this test, instead just filling the sealed ROV with a few 1lb weights to keep it underwater.
Here's the ROV at the bottom of the bucket of water. The two domes - top and bottom - are bolted to the frame with their respective o-rings.
I left the ROV in the bucket for 24 hours to give any small leaks chance to show. I also included some leak indicating tape (https://smile.amazon.com/gp/product/B00MO2R7BC) around the lower dome. This tape turns red if *any* water touches it. If water made it inside, it would flow down over the tape making it very obvious where the leak was.
In the above picture, I've drawn around the indicator tape in blue (this is only a part of it of course). At the end there are no leaks! ... the first time that's every happened with my ROV builds.
Thrusters, wiring, and potting
07/12/2018 at 22:26 • 0 commentsWith the thruster assembled, it's time to attach them to the frame. Each thruster slots into a shroud on the side of the frame and is glued into place using the Rigid resin.
A little scalpel trimming was necessary to make sure the blades of the thruster don't collide with the shrouds (it was designed to be a snug fit which improves efficiency, but I guess things don't come out perfectly true even on the Form2 ... although very close).
Next the wiring was glued into place. The wiring enters at the side and is run around the inside of the frame to the middle (as you can see). My original idea was to feed the wires into the center "ball" from the edge (which is why the wiring enters near the central pivot) but this turned out to interfere with the frames rotation. If I print the frame again I will probably bring the wires directly in at the bottom.
Two sets of wires are brought in at each side. On the left (in the photo) are the wires to drive a thruster, and the wires to charge the battery/turn on the ROV. On the right are the wires for the other thruster, and the ethernet cable.
The wires are then potted using Marine Epoxy (https://smile.amazon.com/Loctite-1919324-0-85-Fluid-Syringe-1405604/dp/B00KH62K50).
Assembling the Thrusters
07/11/2018 at 00:26 • 0 commentsThe thrusters are built around the Turnigy Multistar 1704-1900Kv 12 Pole Multirotor Outrunner V2. The prop and enclosure are printed using the glass fiber rigid Form2 material.
The motors are first sprayed with conformal coating (https://smile.amazon.com/gp/product/B06XWGCKX5). While the Multistar motor can run underwater without issue, the conformal coating provides some level of waterproofing and - hopefully - prevents rust.
The motor screws into the support with a cover on the back for better water flow. The assembled thruster looks like this.
While the majority of the thruster is identical, the two props are mirrored so their rotational forces will cancel out when providing uniform forward or backward thrust.
Glueing the outer frame
07/06/2018 at 00:53 • 0 commentsTime to bite the bullet and glue the outer frame. When this is done the two parts of the outer frame will be attached forever, the metal bar to hang the spherical robot will be in place, and the o-ring channel will be smooth.
I started by printing a supporting jig into which I can bolt the two main frame pieces, holding them in place while the various glues dry.
I first glued some nylon pins into the ends of one frame piece (there are holes in both). This will aid alignment of the frame when assembled and improve its final rigidity. You can see the pin glued here:
The end of the frame has some more superglue applied. This is the first glue used to bond the two pieces of the frame together.
Here you see the frame, bolted into the jig, assembled and waiting for the glue to dry. While the two pieces mate well together, there are small gaps which I needed to fill. If I didn't, they'd provide a path for water to leak in later.
The gaps are filled using a syringe of the Formlabs Rigid resin. A little of this resin is injected into the gaps (and encouraged using a small paint brush). Then more resin is painted into the o-ring groove to make it smooth and continuous. The groove needs to be smooth otherwise water will wick between the o-ring and the surface. This additional resin also helps to two parts bond together (the second glue).
A blue/violet laser is used to cure the resin (which should only be used with the appropriate eye protection because this thing is nasty).
The final results looks like this:
ROV Communications: Going simple
07/01/2018 at 00:41 • 0 commentsAfter a lot of exploring and general indecision, I've decided to go with the simplest communications system for the ROV - good old fashioned ethernet. I seriously considered optical, but the suggested POF stuff is bulky, the optical USB cables very expensive and reviews suggest not very durable, and ethernet over fibers transceivers are - again - bulky.
In an attempt to keep the tether size down, I'm using 3.8mm OD Cat6 (see https://smile.amazon.com/gp/product/B00BIPOC64) rather than the more traditional 6mm cable. There's even some 2.8mm cables out there, but I couldn't find that in 30m lengths; which was a shame.
This compares nicely to BlueRobotic's Fathom Slim ROV tether with has a 4mm OD.
Using the ethernet daughter board I found on Tindie (see https://www.tindie.com/products/marcel/raspberry-pi-zero-ethernet-rj45-and-usb-hub-shield/) I can stack my 8BitModule board on one side of the Pi, and the ethernet connector on the other. The resulting sandwich is in the photo above. I doubt I can get much more compact than this.
Hanging the robot from the frame
06/29/2018 at 23:53 • 0 commentsThe ROV consists of two major parts: the outside frame which houses the thruster on the wet side, and keeps the water out; and the inside ball which contains all the electronics and hangs and rotates the outside frame to vector the thrusters as necessary.
The outside frame (without the acrylics domes) looks like this:
Ultimately this frame will be glued into one piece, with the solid metal bar in the center on which hangs the inner ball. My first design of this robot required that I assemble the ball onto this bar before I glued it all together. This made maintenance and changes impossible without destroying the frame.
This time I've designed the inner ball to be bolted around the bar after the fact:
The above show the electronics part of the ball (right) and a slice of the lower ballast part of the ball (left - I just printed a slice to test the idea before printing the full part). A notch runs down both pieces (approximately in the center of this photo) which fit around the bar. The two pieces are then bolted together.
Other pieces will also be added to the bar in order to position the ball in the center and to allow it to vector the frame using gears and a servo. I'd originally intended to add the gears before gluing the frame, but again I'd prefer not to so I can tweak the design later.
I ended up designing the gears with a cut out to allow it to slip onto the metal bar, and then a "plug" inserted to keep it in place. A little glue might be required to keep these bits together, but I'm less concerned about destroying these small pieces in the event I need to change them.
ROV Communications?
06/20/2018 at 16:25 • 8 commentsI'm still considering various communication options for the ROV. Here are my current thoughts:
- WiFi over co-ax: The only communications built onto the Pi Zero are WiFi and USB. Running USB over 100 ft of cable isn't practical (optical maybe, but that's expensive), so I've been looking at coxing the WiFi single off the Pi and into some 50 ohm cabling. However, there's no balanced connector on the board and while I did try this mod (https://hackaday.com/2017/03/07/adding-an-external-antenna-to-the-raspberry-pi-zero-w/) to add one, the result wouldn't propagate efficiently. I've also tried using an external USB WiFi adapter with a RP-SMC connector, but this was similarly unsuccessful; again probably because the signal isn't balanced. Unfortunately WiFi signaling is way, way, way outside my area of expertise but I still find the approach appealing.
- Ethernet: Next we have Ethernet. Obviously there's no ethernet on the Pi board so one must be added. The most compact option I've found is to use this board https://www.tindie.com/products/marcel/raspberry-pi-zero-ethernet-rj45-and-usb-hub-shield. Ethernet then opens up some sub-options:
- Cat5: Traditional ethernet is an easy option at this point. 100ft of ethernet is a little bulky. But it's simple.
- Cat3: Taking a step back in time, Cat3 cable should be good enough to run 10Mbits which is enough for control and video (we're not talking 4K here!) The cable is significantly less bulky.
- Powerline: Powerline offers the speeds of 200Mbits with even less cable bulk at only two wires. However it requires an extra adapter (found here https://www.bluerobotics.com/store/electronics/fathom-x-tether-interface-board/ and here https://www.aliexpress.com/item/WisPLC-development-board-Power-line-twisted-pair-Ethernet-interface-200M-Transmission-rate-transmission-of-IPTV-HDTV/32791324046.html) which plugs into the ethernet. It's a little annoying that the only purpose of the ethernet jacks are to plug these two together, and perhaps someone might create a board which does away with these parts.
- USB over ...?: I mentioned USB as not being practical, but if there is a way to run it over 100ft of inexpensive cabling I'd love to know.
My previous ROV has taken the Powerline approach, but before simply taking this route I want to explore all the options. I'd be interested in any feedback.
Material choices
06/10/2018 at 21:00 • 0 commentsThe main body of the ROV consists of two printed pieces, each a semi-circle with a moulded thruster shroud, entry points for cables, and holes to attach the plexiglass domes.
---------- more ----------The making of this part has been a major obstacle in building the ROV.
My first attempt at building this part used layers of acrylic, each laser cut slightly differently and bonded together. This allowed me to create the smooth grove needed for the o-ring between the domes and the body. But it was extremely messy and temperamental, and there was no way to build the thruster shrouds.
My second attempt 3D printed these parts on a Prusa printer using dissolvable support material. While this enabled me to get the exact shape I needed, the o-ring grove isn't smooth and so water would leak. I tried using a Smooth-On coating to give the grove a smooth texture, but this got messy quickly and was also unreliable.
My third attempt printed these parts on a Form2 from Formlabs. The advantage of using a resin printer is that I can print a completely smooth surface and produce the exact shape I needed. However, I found that regardless of resin (White, Tough and Durable were all tried) the parts were not stiff and would slowly deform due to the weight the the inner robot hanging from them.
And so onto my forth attempt (the current iteration). This again uses the Form2 but this time with their brand new Rigid resin which is, essentially, a fiber glass mix. I have high hopes that this material will offer all the material properties I need.
