topFrame.stl
for PULSE PACK enclosure
Standard Tesselated Geometry - 367.56 kB - 10/21/2018 at 23:40
Download
Harness_Adaptor.stl
Standard Tesselated Geometry - 104.77 kB - 10/21/2018 at 23:39
Download
bottomFrame_inside.stl
Standard Tesselated Geometry - 132.70 kB - 10/21/2018 at 23:39
Download
Base_1.stl
Standard Tesselated Geometry - 277.04 kB - 10/21/2018 at 23:38
Download
harnessMounts.stl
- 218.25 kB - 10/21/2018 at 22:59
Download
Joint_bottom.stl
- 49.79 kB - 10/21/2018 at 22:59
Download
bottomFrame.stl
- 435.92 kB - 10/21/2018 at 22:59
Download
port.stl
- 497.05 kB - 10/21/2018 at 22:59
Download
heart_Bracket.stl
- 40.61 kB - 10/21/2018 at 22:59
Download
washer.stl
- 38.17 kB - 10/21/2018 at 22:59
Download
heart_Bracket_long.stl
- 32.80 kB - 10/21/2018 at 22:59
Download
Base_3.stl
- 118.15 kB - 10/21/2018 at 22:59
Download
Base_2.stl
- 184.55 kB - 10/21/2018 at 22:44
Download
heartSpacer.stl
- 58.97 kB - 10/21/2018 at 22:44
Download
portNut.stl
- 119.61 kB - 10/21/2018 at 22:44
Download
Joint_top.stl
- 96.47 kB - 10/21/2018 at 22:44
Download
shebon_heart.brd
PULSE PCB : EAGLE design file
brd - 181.69 kB - 10/21/2018 at 21:35
Download
shebon_heart_schematic.pdf
PULSE board schematic
Adobe Portable Document Format - 106.79 kB - 10/21/2018 at 21:35
Preview
pulsePCB_Gerbers.zip
PULSE gerber files
Zip Archive - 579.92 kB - 10/21/2018 at 21:35
Download
pulsePCB_BOM.txt
PULSE PCB bill of materials
plain - 6.30 kB - 10/21/2018 at 21:35
Download
face_plate.stl
POPgirl face plate
Standard Tesselated Geometry - 365.12 kB - 10/20/2018 at 17:07
Download
arm_mount.stl
POPgirl arm plate
Standard Tesselated Geometry - 272.64 kB - 10/20/2018 at 17:07
Download
2mm_spacer.stl
POPgirl 2mm spacer
Standard Tesselated Geometry - 35.04 kB - 10/20/2018 at 17:07
Download
17mm_spacer.stl
POPgirl 17mm spacer
Standard Tesselated Geometry - 58.09 kB - 10/20/2018 at 17:07
Download
PCB_mount.stl
POPgirl PCB mount
Standard Tesselated Geometry - 130.36 kB - 10/20/2018 at 17:07
Download
screen_capture.stl
POPgirl screen capture
Standard Tesselated Geometry - 114.54 kB - 10/20/2018 at 17:07
Download
gasket.stl
POPgirl screen gasket
Standard Tesselated Geometry - 60.63 kB - 10/20/2018 at 17:07
Download
5_5mm_spacer.stl
POPgirl 5.5mm spacer
Standard Tesselated Geometry - 50.18 kB - 10/20/2018 at 17:07
Download
3mm_spacer.stl
POPgirl 3mm spacer
Standard Tesselated Geometry - 34.65 kB - 10/20/2018 at 17:07
Download
