The components that are necessary to get it working are:
- 32.768kHz crystal and 22pF caps
- Reset pullup and button
- 3.3V voltage regulator
- power capacitors
A small, minimal breakout board for the SAMD51
samd51breakout.schsch - 291.89 kB - 06/25/2018 at 20:40 |
samd51breakout.brdbrd - 104.34 kB - 06/25/2018 at 20:40 |
This is a great idea for those that want to use all the I/Os on the chip. The footprint is similar if not identical to the samd21 depending on the suffix and the PCB might be interchangeable. Leaving 5 or 15 pins unavailable as a dev platform should be a crime. Its hard enough to find a full 8 pin contiguous port for I/O that isn't interlaced with a vital serial, crystal or other peripheral I/O right in the middle of it. When you limit a chip with this capability on port pins, you aren't doing it any favors. If Microchip would get on the ball and get an Xplained board out for $30, I'd buy it.
First, this is something I've been looking for for a while.
Is the crystal necessary? I ask because the ItsyBitsyM4 doesn't have one. Also does the VDDCore connect to anything?
