OpenTorque Actuator
Back to overview
A powerful, compliant actuator for legged robotics
Zhi Ern Teoh wrote 04/23/2021 at 02:52 point
Hi! How did you insert the bearings into the planet gears? It looks like the ID of the chamfered entrance is 14 mm but the OD of the bearing is 16 mm. Did you use a drill to widen the hole after printing?
