Flir module for the cyborg helmet
08/11/2018 at 15:47 • 0 commentsHere is a link to buy the flir unit I propose using , $161 isnt bad.
Thermal Selfie Style!
08/11/2018 at 14:52 • 2 commentsIn honor of the future integration of thermal view in the AR HUD, a Thermal Selfie ! What do you guys think, Hot or Na ? Disclaimer, these are NOT pictures through the cyborg helmet, it is not assembled yet, just me having fun.
outside at the solar farm
prototype 2 starting
08/10/2018 at 22:08 • 0 commentsOK so this begins try 2, this is nor a hardware or implementation issue, I simply had a happy accident and found that another cheap headset has some features I could exploit. Of course in the name of open builds I want to use something easily attainable by the maker community, that being said I found the Lenovo Jedi Challenger game headset to have a set of optics that I think would work great to exploit! I found one as low as 45 dollars then offered $30 and the seller accepted it. Boom , replacement on the way. These are regularly 40-60 on ebay because the game itself is a bit of a flop for the price. This headset has a clear outside lens that I think I may be able to use in the end and would look better that piece work. I will still post 3D printable versions and VR goggle conversion instructions as well so everyone can join the fun!
Update
08/10/2018 at 21:26 • 0 commentsHello all! I descided to ditch this headset , not because it was not going to work, , but because I shattered it into a million pieces when my saw blade caught the plastic and resin the wrong way. I did however continue to play with it and widened the body a great bit to see if I could like up 3 screens. I can do it however it looks " really big" as to how large the headset will be and I think it may not be aerodynamic at that point, so back to the drawing board. Here are the pics after it exploded and I cut the edges and spread them out to widen field of view.
I will measure out this work in progress and draw it as a STL that can be printed. I hope everyone finds that useful if you want to make a version for yourself.
360 degrees of cameras
08/04/2018 at 16:17 • 0 commentsDay/Night Pi Zero W with 5mp 120 degree lens , Each comes with IR LEDs which I may or may not use. I will determine this after testing. The Pi will be mounted under the abs helmet shell and hole drilled to expose the camera lens. SD card is 64gb Sandisk High endurance. Wifi is a connection option ,but I would like to solder a direct USB connection. I originally planned to have only two of these ,but I may do two side cams.
EZ-Robot, EZ-Builder Software
08/04/2018 at 15:49 • 0 commentsThere is a SDK for Raspberry pi if you are brave enough to go that route, for version one of this project I will stick with the well ironed out x86 version of ez builder. this helps you build code and collaborate with others to integrate modules that other members can help you build as well. I recommend it for anyone starting in robotics or automation of any kind. EZ Builder is free, if you want to interface sensors or servers ect then you can get started for as little as $25 for EZ IOtiny board as a data interface either through WIFI , or USB TTL interface.
https://www.ez-robot.com/EZ-Builder/ , download link, completely free, regular updates and improvements both from the core developer and other users as well.
Instructions for download and setup tutorial
Second Screen USb 3.0 adapter
08/04/2018 at 13:39 • 0 commentsI need a second screen and a USB 3.0 adapter seems to fit this bill in this case. This one was purchased from amazon and should be here Tuesday , but hopefully sooner. 21.99
https://www.amazon.com/gp/product/B078P9CF28
- 【USB3.0 to HDMI CONVERTER】 Insert the USB port on your computer, and connect an HDTV, monitor, or projector via extra HDMI cable ( cable not included ); Then you can use a second display to increase efficiency. ---- NOTE: ONLY Support Windows 10, Windows 8, Windows 7 Computers.
- 【MIRROR / EXTEND DISPLAY】Whether showing movies on a big-screen HDTV or expanding a workstation by extending a desktop to a second monitor or mirroring screens for a better presentation on a projector, this USB3.0 to HDMI adapter make a convenient connection. Supports multiple monitors with additional adapters.
- 【1080P FULL HD VIDEO】This USB3.0 to HDMI Adapter allows for video resolution up to 1920*1080P full HD, ideal for home theater entertainment, conference room, office or teaching at school etc.
- 【SUPER SPEED】Transmission Speed of USB 3.0 is up to 5Gbps for the best performance, equal to an external graphics card to deliver smooth high definition video to your HDTV/ projector or monitor.
- 【SIMPLE INSTALLATION】 This USB3.0 to HDMI Adapter with internal drivers for download; If you cannot get it work with the internal driver in the device, please manual download & install the latest driver from our website, Please search " Download - Hoplaza " from GOOGLE.
The Brain , hardware, Latte Panda, Yum Coffee
08/04/2018 at 13:06 • 0 commentsI have decided for version one, Windows 10 OS and the Latte Panda will be a good start. This is because EZ-Robot is native to windows platform and there are already API that I can use for windows for voice command / voice recognition. This does not however exclude using the raspberry pi as I am still going to use these boards for other purposes like the video recording and pi cams as well. In this version of the AR HUD I will use two HD displays using HDMI, the panda ( and almost all other sbc) only has one hdmi output, so I will use the USB3.0 to emulate another one for the second screen.
Speech APi I am using Google Cloud
08/03/2018 at 21:31 • 0 comments -
Great Object Recog project
08/03/2018 at 18:48 • 0 commentshttps://hackaday.com/2018/07/31/object-detection-with-tensorflow/
This looks like a cool project that anyone building one of these AR goggle helmets. I post this to give anyone following options when they build their own custom AR helmet!
Josh Starnes
