Implements a text mode VGA controller for the Nexys 4 DDR FPGA development board. The controller outputs 720x400 at 70 Hz which is compatible with the IBM VGA industry standard (non-VESA mode). Character resolution is 80x25 using a 9x16 glyph. The controller includes a CRT controller, a 32 Kb video RAM, a character generator, a 4 KB character ROM, an attribute generator, and a synchronizer. The text attribute matches the original VGA 16 colors, with both background and foreground color capability. A cursor is generated by the CRT controller and can be enabled and disabled. The included PicoBlaze program tests the character ROM, text attributes, and cursor.
For your VGA controller, would mind sharing your vsync/porch values please? I'm trying to get a 720x400 display working with my FPGA but I seem to be missing 50 lines from the top of each frame.
