The Last Update For a While
08/16/2018 at 23:08 • 0 commentsSeveral issues have been pointed out that would not be fixed by replacing the wobbly worm gears. Each issue could be addressed individually, but this would be time-consuming.
Therefore I've decided to reduce the scope of my efforts. I plan to continue testing the Pi and DC motors, but to use a conventional, cartesian robot that will be similar (or identical?) to existing open-source designs. This will reduce complexity and make debugging much simpler.
Since I'm rebuilding the robot anyway, I might as well invest in higher-accuracy sensors. Perhaps I'll get some optical encoders. Alternatively, I might make an attempt at using computer vision- others on this website have had success with this approach. I would have to purchase and calibrate a camera of sufficient resolution, but OpenCV definitely has the capability to do this sort of thing (at least to moderate accuracy).
I'll probably post something to this website when (if) I get another robot built and working. But it will probably be a few months (or even a few years).
Loose Motor Shafts
08/08/2018 at 02:19 • 0 commentsThis shows that the motor shafts are loose, causing inaccuracy. I can rotate the motor shafts several degrees before encountering resistance from the gears. This reduces the accuracy of the machine.
The CNC Works (Sort of)
08/08/2018 at 02:15 • 0 commentsThe robot attempted to write "HI". The writing is difficult to read, but it is possible to distinguish the letters if you look carefully.
Daniel James Evans
