The single chip embedded Linux board
I wrote a tutorial on my Github wiki, on how to create your own custom image for the Blueberry PI.
Since the Allwinner V3s only has 64Mb of RAM, it is a very smart decision to customize your image to fit your needs.
You only need a running Ubuntu / Debian (or other distros) on your PC.
However some knowledge about the Linux terminal is required.
Since the V3s has a parallel RGB interface, it can directly drive LCD's like the AT050TN33 (480x270) or other even bigger LCD's like the HW800480F-3E-0B-10 (800x480). The Blueberry PI is compatible with every 40 pin RGB LCD.
Since many people were really interested in buying a Blueberry PI, I fixed some minor issues on the current PCB and ordered new PCB's. I will start selling the Blueberry PI on Tindie in the near future.
hi dear
is it true the MIPI-CSI is not yet supported in the Linux kernel?????
Hi looking to make a bespoke version of the raspberry pi for a project im working on at the moment. Just wondering how you went about it
Hi
I have a few old phones lying about, I was wondering if anyone knew if it would be at all possible to follow this Guide on this to a degree and use one of the more powerfull CPU for this?
Can I run this board with battery? Can I use 50 pin RGB LCD using this processor? Do I need any hi-speed layout in this board?
Would this: https://www.adafruit.com/product/2354 work as a display?
Yes it will work, but you can get them cheaper on ebay or aliexpress.
No, I'm using the EA3036 3 channel DC DC step down converter
Hi,
thanks for the feedback. I updated the schematics and also uploaded the schematics as pdf.
I will keep you guys updated.
Hi, very interesting project!
On your github there are only Eagle files... Could be possible to have the schematic on pdf...?
Keep us updated please!
How much did this cost?!
