Computer050.zip
Added byte addressing mode; fixed couple of wiring bugs. Additionally, the simulation is pre-loaded with integer calculator program (decimal input and output), which does additions, subtractions, multiplications and divisions (also can calculate remainder of division). Numbers can be up to 9 digits long.
application/x-zip-compressed -
1.67 MB -
01/13/2020 at 06:37
Download
Computer042.zip
Several bugs fixed, addressing logic remade from scratch, so it more regular, plus adding true subroutine calls. Comes pre-loaded with 16-bit positive integer multiplication program, input and output are hexadecimal.
x-zip-compressed -
2.29 MB -
12/12/2019 at 05:44
Download
asm3.zip
Third version of assembler; supports constant and address labels, several directives.
x-zip-compressed -
1.46 MB -
12/12/2019 at 05:42
Download
asm2.zip
Second version of assembler: couple of bugs fixed, now can have arbitrary number of spaces in lines, and, most important, address labels are supported.
x-zip-compressed -
1.43 MB -
11/30/2019 at 08:20
Download
asm.zip
simple assembler for code for use with simulated computer
1.43 MB -
11/24/2019 at 13:24
Download
Computer04.zip
Simulation files for computer described in this project + documentation of its instruction set. (Updated with new instructions and execution cycle) (zip archive)
284.03 kB -
11/18/2019 at 17:12
Download
Computer04.7z
201.14 kB -
11/18/2019 at 06:49
Download
Computer03.7z
172.55 kB -
11/11/2019 at 06:44
Download
