Erasing the EPROMs, how-to
10/03/2018 at 08:07 • 0 commentsIn case there is a need to wipe the entire EPROM contents, the most easy way is to use the UV-EPROM eraser (pic below).
It has UV light source inside which will erase everything in minutes. In my case I put my entire memory-bank inside and it is ready to use again. Easy
additional info about programming
10/02/2018 at 22:21 • 0 comments -
new parts which might be useful
10/02/2018 at 22:15 • 0 comments -
Manual Programming modes
10/02/2018 at 22:13 • 0 commentsFor hardcore folks there is a hardware programming mode. One can add DIP 16 bit switches to manually enter data into the memory-card. Any ideas or thoughts about this would be interesting.
PCB version v1.0
10/02/2018 at 22:05 • 0 commentsthere is going to be an update for the UV-EPROM memory card soon. I am planning to make a solid PCB board which one can plug. Its going to be a parallel interface and maybe additional a nice lock-in mechanism.
Dave_ Z.
