Battery charging up to 500mA and powering any 3.3V project up to 600mA
basically my 3v3 regulator + lipo charger power muxer combo from the lameboy
pwr.schEagle schematic filesch - 521.52 kB - 09/20/2018 at 10:53 |
pwr.brdEagle board filebrd - 95.09 kB - 09/20/2018 at 10:53 |
pwr.pdfschematic as pdfAdobe Portable Document Format - 16.67 kB - 09/20/2018 at 10:53 |
Archive.zipGERBER filesZip Archive - 40.57 kB - 09/20/2018 at 10:53 |
Here's a link to the instagram image, let's see how it performs :)
I went over the design with a rested eye and everything looked good to go - hope it makes it in time to test, but I call it verified since it's working in my #LAMEBOY - another ESP12 handheld already anyway. I used super-swift but I was too cheap for upgrading the shipping :D
me too, it sounds a bit pricey if you compare it to a diode solution. But then again you can't really compare that to a diode solution :D
Well, I just use the power switch to switch between battery and usb -- no diode :)
@ꝺeshipu wouldn't you reset / restart your gadget that way?
Sure, but I don't mind. I guess I could add a large capacitor if I wanted to prevent that.
Woah, I like the TPS2113A
