square inch power muxer
basically my 3v3 regulator + lipo charger power muxer combo from the lameboy
Battery charging up to 500mA and powering any 3.3V project up to 600mA - uninterrupted 3.3V, just plug in 5V to your liking.
pwr.sch
Eagle schematic file
sch - 521.52 kB - 09/20/2018 at 10:53
Download
pwr.brd
Eagle board file
brd - 95.09 kB - 09/20/2018 at 10:53
Download
pwr.pdf
schematic as pdf
Adobe Portable Document Format - 16.67 kB - 09/20/2018 at 10:53
Preview
Archive.zip
GERBER files
Zip Archive - 40.57 kB - 09/20/2018 at 10:53
Download
  • 1 × TPS2113 Power Management ICs / Power Supply Support
  • 1 × MCP73831 Power Management ICs / Power Supply Support
  • 2 × 4.7 uF 0805 capacitor
  • 2 × 1uF 0805 capacitor
  • 1 × USB micro plug connector
View all 15 components
View all 2 project logs
Jarrett wrote 09/07/2018 at 22:44 point
Woah, I like the TPS2113A
davedarko wrote 09/07/2018 at 22:45 point
me too, it sounds a bit pricey if you compare it to a diode solution. But then again you can't really compare that to a diode solution :D
deʃhipu wrote 09/07/2018 at 22:59 point
Well, I just use the power switch to switch between battery and usb -- no diode :)
davedarko wrote 09/07/2018 at 23:16 point
@ꝺeshipu wouldn't you reset / restart your gadget that way?
deʃhipu wrote 09/07/2018 at 23:39 point
Sure, but I don't mind. I guess I could add a large capacitor if I wanted to prevent that.
