Receiver.rarThis folder contains all the codes used in the project, at the receiver end.RAR Archive - 535.38 kB - 11/29/2018 at 11:09 |
UM10139.pdfUser manual of the development board used at both the transmitter and the receiver side.Adobe Portable Document Format - 1.56 MB - 11/29/2018 at 04:16 |
Receiver_Code.cThis is flashed to the LPC at the receiver end. Link to the LCD code used - http://www.rhydolabz.com/wiki/?p=7164C Source File - 12.90 kB - 11/29/2018 at 04:14 |
hut1_12v2.pdfThe Usage Tables give the look-up values for the data to be sent over USB.Adobe Portable Document Format - 949.63 kB - 11/28/2018 at 22:28 |
Block_Diagram.JPGA block diagram of the system.JPEG Image - 50.92 kB - 11/28/2018 at 21:57 |
transmitter_code.cThis is flashed to the LPC at the transmitter end.C Source File - 1.01 kB - 11/28/2018 at 21:25 |
