PCBs Arrive & Lasering an Enclosure
10/07/2018 at 01:22 • 0 commentsPCBs arrived from OSHPark a bit earlier than expected (past the challenge deadline, but that's my own doing)! Just a bit of cleanup, and they'll be ready for soldering (once the DigiKey order arrives).
I decided to do a negative raster on the top acrylic layer, such that everywhere my text and images weren't were engraved, to allow more diffuse area for the LEDs to shine through:
The image is of the Angel Moroni (an important symbol of missionary work in my church), and the text is a translation of "God Be with You 'Til We Meet Again".
The lasering turned out really well!
Prototype for Firmware Development
10/07/2018 at 00:49 • 0 commentsI plan on programming my boards using ArduinoISP from my Arduino UNO, so I thought I would get a jump-start on firmware development and testing an ISP setup by building a breadboard prototype of my circuit (as I've always programmed over UART in the past).
I soldered together a little SIP ISP programming header, and set the fuses of a DIP ATmega328P with Optiboot I had laying around to run with the 8MHz internal oscillator (since I didn't have a 16MHz crystal on hand, Nick Gammon's wonderful Arduino tools helped me out with an alternate clock source). On the actual board, I plan on using the 8MHz oscillator for the CPU, and running a Timer2 RTC with an external 32KHz crystal. After laying things out (including a button to simulate the touch sensor), a simple test program (blinking one of the Charlieplexed LEDs) worked great:
PCB Layout Fail (And Fix)
10/07/2018 at 00:27 • 0 commentsEarly on the PCB layout process, I used an "0603" footprint for most of my passives and my LEDs, and finished what I thought was a great component layout. Everything was fitting a little too well, with lots of extra room... Upon further inspection, I found that the footprints were really 0603 metric, or 0201 imperial, and I was further taught that almost all hobby PCB design and SMD parts are referenced in internet parlance in imperial. There goes my "bigger than a grain of rice" requirement...
After reworking my component sizes up to 0603 imperial, I was finally able to get a good component layout, connected up traces, placed ground planes, and finished my first PCB design!
In addition to the LEDs, regulator, ATmega, and cap sense chip, I added a jumper to a pad that could allow an external capacitive touch pad if the 6mm one under the OSHW logo isn't sensitive enough. I also made the footprint for CS1, the capacitive touch sensitivity adjustment cap, 1206, so I could get a few values to experiment with and hand-solder them. Time to whip up a BOM and design an enclosure!
Idea & Research
09/15/2018 at 19:10 • 0 commentsI've wanted to build something for the square inch project since the original challenge announcement, but most of my ideas have involved the ESP8266 or ESP32, and were a bit too grandiose for my first foray into PCB design. So with a few weeks left, I thought I'd build a blinky memento for my upcoming mission trip. The basic idea is a square inch flag-themed LED grid with 1 LED for each month I'll be gone.
My wish list after that includes:
- Lasting the full 2 years (preferably without recharging, and on a coin cell for assembly convenience)
- General robustness, so that these can be carried/worn if desired - Leads me to think of a wooden/acrylic case and a capacitive touch sensor to trigger an MCU wake and the animation
- Keeping track of time accurately enough for at least to-the-month granularity over the 2 year runtime (without resets or other functionality-breakers)
- Relative ease of assembly and programming (time's running mighty thin!) - Arduino compatibility and parts bigger than grains of sand are preferable (though I'll likely be hot-plate reflowing)
I considered several options for how to achieve the functionality I was going for, including consolidating processing and low-power capacitive touch interrupts with the ATmega328PB, but this didn't seem to be well-supported in the Arduino environment, and required a Windows-based proprietary tool to setup the touch sensing.
Instead, I decided to use a plain-old ATmega328P and an AT42QT1010 momentary capacitive touch sensor - the board was starting to look a little tight! For 3.3V power from a 3V CR2032 coin cell, I decided to use an MCP1625 boost regulator. Things look to be coming together!
