SimpleG-end.gcode
G-Code file for when I hit CTRL+C during laser cutting operation. Ensures to home and turn off the laser AFTER the grbl buffer has been cleared. If you run lots of small vectors, GRBL will home immediately. But if you run long straights, the buffer will need some time to empty. In that case, please just turn the laser off by manually switching the laser_on switch on your cutter and let it finish properly.
gcode -
18.00 bytes -
11/18/2018 at 23:14
